If you’ve been roaming Appalachia for a while, you know how essential Caps are in Fallout 76. Whether you want to buy plans, legendary gear, or just keep your stash stocked with supplies, a steady flow of Caps is vital. One of the best ways to earn them is by selling loot to NPC vendors scattered around the map.
Unlike player vending, these NPC vendors have daily Cap limits (usually 1400–1500 Caps shared across their faction), so knowing where to go and how to route them efficiently is key. Here’s a list of 10 great vendor locations you should visit to maximize your Caps farming runs.
1. Whitespring Resort
Whitespring is a classic stop for any Caps run. It has multiple vendors inside the shopping arcade, all of whom share the same Cap pool. While they drain fast if you’re selling bulk legendaries, it’s still a top spot thanks to its centralized location and convenient workbenches.
2. Watoga Shopping Plaza
Watoga is your urban vendor hub in the Cranberry Bog. The shopping plaza hosts two vendors (RobCo and Brotherhood of Steel) sharing the same pool. It's worth the trip if you're already down south farming high-level enemies or events.
3. The Rusty Pick
Located in the Ash Heap, The Rusty Pick’s vendor is especially handy if you’re selling off legendary weapons you don’t want. While you’re here, you can also pick up Legendary Scrip or trade at the Purveyor.
4. Camden Park
This spot in the Forest has a single vendor but is often overlooked by other players. It’s good for topping off your Cap run if you’ve already exhausted other vendors. Plus, Camden Park has some fun carnival-themed loot for roleplayers or collectors.
5. Charleston Station
Near Charleston itself, this station vendor is a reliable Forest-region stop. It’s easy to reach early in your route, especially if you’re fast-traveling between the Forest and Ash Heap.
6. Pleasant Valley Ski Resort
Located in the Savage Divide, this vendor often gets skipped by people rushing to Whitespring. But the Raider vendor here is a separate faction pool, making it ideal if you’ve emptied the Whitespring vendors already.
7. Grafton Station
Grafton Station is another Forest-region vendor with a separate Cap pool. If you're running loops in the Forest for events or public teams, it’s a convenient stop for selling excess loot.
8. Harper's Ferry
Located in the Mire, this settlement vendor is easy to miss but very useful. It’s a great mid-map option, especially if you’re farming enemies in the Mire or heading toward the Cranberry Bog.
9. Foundation
If you’ve sided with the Settlers, you’ll know Foundation well. Their vendor has its own Cap pool and is easy to access once you’re down south. It also has crafting stations, making it convenient for scrapping before you sell.
10. Crater
The Raider counterpart to Foundation. Crater is in the Toxic Valley and has a separate vendor pool. It’s essential to include both Crater and Foundation in your route to maximize your daily sales.
Tips for Efficient Caps Runs
Plan your route: Try to group vendors by region to avoid wasteful fast-travel costs.
Sort your loot: Focus on high-value, low-weight items so you don’t get overencumbered halfway through.
Scrap first: Reduce weight at workbenches before selling.
Use your stash: Keep overflow you can’t sell today for tomorrow’s vendor resets.
Consider your needs: If you’re going to buy Fallout 76 Items, having plenty of Caps on hand gives you flexibility to grab what you want from other players.
Selling to vendors is still one of the easiest, most consistent ways to farm Caps in Fallout 76. Even if you also trade with players or Buy Fallout 76 Caps online to save time, vendor runs remain a staple of daily gameplay.
So, plan your loop, grab your junk and legendaries, and hit these spots to turn Appalachia’s loot into the sweet sound of jangling Caps. Safe travels out there, Vault Dweller.
