howto check SPF working
JOP
Post by JOP »
it seems SPF on efa5 is not working. Ho to check it is working?
Re: howto check SPF working
You'll need to provide more information.
What exactly is not working and how do you know?
Since you've provided essentially no information, all I can suggest is to start here: https://mxtoolbox.com/SuperTool.aspx and check your spf record for your domain to see if there are any problems there.
