Greylist vs banking auth code
Posted: 05 Feb 2025 07:27
by conceptid
how are you dealing with banking 2FA auth code by mail with greylist?
Often there is a 10 minutes timed out to use the code... and also each time a code is sent, that mail arrived from different server... So the code is always stuck in greylist...
Re: Greylist vs banking auth code
Posted: 10 Feb 2025 23:45
You can add the bank's domain to /etc/sqlgrey/clients_fqdn_whitelist.local and run
sudo update_sqlgrey_config
