spamassassin --lint
Posted: 02 Jan 2025 08:12
i realized that i get the error below when i manually mark messages as SPAM in the web gui.
now checking this
As i was only using eFa-Configure i would like to ask if somebody could tell where to correct ?
Thx
SA Learn netset: illegal IP address given (patricia trie): 'macmini.xxx.de/128': invalid key at /usr/share/perl5/vendor_perl/Mail/SpamAssassin/NetSet.pm line 183., , netset: illegal IP address given (patricia trie): 'xxx.de/128': invalid key at /usr/share/perl5/vendor_perl/Mail/SpamAssassin/NetSet.pm line 183., , netset: illegal IP address given: 'xxx.de', netset: illegal IP address given (patricia trie): 'home.xxx.de/128': invalid key at /usr/share/perl5/vendor_perl/Mail/SpamAssassin/NetSet.pm line 183., , netset: illegal IP address given: 'home.xxx.de', Learned tokens from 1 message(s) (1 message(s) examined)Code: Select all
[root@derb ~]# spamassassin -V
SpamAssassin version 4.0.1
running on Perl version 5.32.1
[root@derb ~]# spamassassin --lint
Jan 2 08:47:09.827 [1804993] warn: netset: illegal IP address given (patricia trie): 'macmini.xxx.de/128': invalid key at /usr/share/perl5/vendor_perl/Mail/SpamAssassin/NetSet.pm line 183.
Jan 2 08:47:09.829 [1804993] warn: netset: illegal IP address given (patricia trie): 'xxx.de/128': invalid key at /usr/share/perl5/vendor_perl/Mail/SpamAssassin/NetSet.pm line 183.
Jan 2 08:47:09.832 [1804993] warn: netset: illegal IP address given: 'xxx.de'
Jan 2 08:47:09.832 [1804993] warn: netset: illegal IP address given (patricia trie): 'home.xxx.de/128': invalid key at /usr/share/perl5/vendor_perl/Mail/SpamAssassin/NetSet.pm line 183.
Jan 2 08:47:09.834 [1804993] warn: netset: illegal IP address given: 'home.xxx.de'As i was only using eFa-Configure i would like to ask if somebody could tell where to correct ?
--- Welcome to the eFa Configuration program ---
--- https://www.efa-project.org ---
Description:
All mail domains for which this system accepts mail need an destination server.
Below is the list of current smtp mail domains on this system.
1) home.xxx.de macmini.xxx.de
2) xxx.de macmini.xxx.de
3) xxxtest.de macmini.xxx.de
n) Add new mail domain
e) Return to main menu
