filename.xml.pdf - Allowlisted, Bad content [SOLVED]
SelfMan
Post by SelfMan »
Hi guys,
our eFa 4.0.4 with MailScanner v5.5.1 is blocking file attachments with double extension ".xml.pdf" even though I modified the filename.rules.conf to allow it using:
allow \.xml\.pdf - -
The message details say:
Blocked File: Y
SPAM Allowlisted: Y
Any hints/ideas why that is?
_M_P
Re: filename.xml.pdf - Allowlisted, Bad content
Post by _M_P »
maybe
# allow XMLs converted to PDFs
allow<tab>\.xml\.pdf$<tab>-allow XMLs converted to PDFs<tab>-
is better?
Best regards
SelfMan
Post by SelfMan »
thanks for the reply _M_P,
I copy/pasted one of the original lines so the tab-formatted content was there the whole time.
I just didn't use the </> code formatting here in the forum. (in hinesight, I should have)
And I also did restart the MailScanner.
_M_P
Post by _M_P »
...ok for tabs (are there!), but with a closer look, you'll notice that my RegEx is not the same of your (you missed a $)...
Kind regards
SelfMan
Post by SelfMan »
Ah, apologies! Brain fart! oh no Eyefart or something dumb.
Thanks for your patience.
I've re-formated a couple lines that were added over time but the e-mails are still being filtered.
"The following e-mails were found to have: Bad Filename Detected"
_M_P
Post by _M_P »
I'd try a
mailscanner --lint
Best regards
SelfMan
Post by SelfMan »
I've run the --lint test which found couple other entries with syntax errors that I fixed. (yeah, there were still spaces instead of tabs)
They are now fixed and there are no errors reported. Yet, the pdf file I renames to file.xml.pdf is still filtered out:
"Report: MailScanner: Attempt to hide real filename extension (file.xml.pdf)"
And it ended up in the quarantine.
I've also tried to add the entry to "filetype.rules.conf", but it had no effect.
SelfMan
Post by SelfMan »
Ok, I found the "issue".
The sequence of rules is important.
The general rule for double extensions MUST be last in the sequence of rules.
# Deny all other double file extensions. This catches any hidden filenames.
deny	\.[a-z][a-z0-9]{2,3}\s*\.[a-z0-9]{3}$	Found possible filename hiding				Attempt to hide real filename extension
When I moved the rule, all started to work.
