Hello, I have recently taken over a small company that still uses the efa3 spam filter. Is it still possible to install Version 4 of efa so that i can update to the 4 and then to the 5 efa version as an intermediate step?
efa3 to efa4
Re: efa3 to efa4
Yes.
Use EL8 of your choice to get eFa 4.
Use EL9 of your choice to get eFa 5.
Re: efa3 to efa4
I tried today and always the same error: Failed to download metadata for repo "appstream": Cannot prepare internal mirrorlist: Curl error (6):Couldn't resolve hostname for http://mirrorlist.centos.org/?release=8 ... nfra=stock
Is there a way to upgrade from efa3 to efa5 directly?
Re: efa3 to efa4
You should get to eFa4 first...
Looks like appstream was moved to vault.
Give this a try:
https://medium.com/@bonguides25/fixed-f ... 1ad6db8f16
Give this a try:
