Ability to download .EML mail
gregecslo
Post by gregecslo »
Hi.
Sometimes we need .EML file for various reasons... So we copied it over sftp, webmin etc...
So I had enough and wrote simple EML downloader, it is not pretty but it does job well.
Can it be included in next efa version?
How I did it:
Create file: /var/www/html/mailscanner/dl_mail.php
<?php
// Get the path from the URL parameter
$path = $_GET['path'];
if (file_exists($path)) {
    $basename = pathinfo($path, PATHINFO_FILENAME);
    $tempFile = tempnam(sys_get_temp_dir(), $basename);
    $emlFile = $tempFile . '.eml';
    rename($tempFile, $emlFile);
    copy($path, $emlFile);
    $filename = $basename . '.eml';
    header('Content-Type: application/octet-stream');
    header('Content-Disposition: attachment; filename="' . $filename . '"');
    header('Content-Length: ' . filesize($emlFile));
    readfile($emlFile);
    unlink($emlFile);
} else {
    // Handle the case where the file doesn't exist
    echo "File not found.";
Then in: /var/www/html/mailscanner/detail.php
Added to the very end:
// Add footer
html_end();
// Declare paths for mail download
$first_path = $quarantined[0]['path'];
// Download it
echo '<td>' . '<a href="dl_mail.php?path=' . urlencode($first_path) . '" target="_blank">Download .EML</a>' . "</td>\n";
// Close any open db connections
dbclose();
And now I can download mail in EML format from detail page.
It would be awesome if this would be a native feature...
Re: Ability to download .EML mail
Sounds like a great feature!
Be sure to submit an issue to https://github.com/mailwatch/MailWatch for this feature 8-)
gregecslo
Post by gregecslo »
Done
barbours
Post by barbours »
After Shawns departure, We have forked the project over to openefa.com and integrated AI and a natural language server SpaCy server. We are working on our first release. Are you available for a discussion about eFa future? Call me at 7025618743 or email at scott@seguelogic.com. new site is https://openefa.com
We are interested in adding this feature. Give me shout to discuss how you see it being implemented
barbours
Post by barbours »
I have integrated this in my EFA filter and
will be integrating it into the first release of OpenEFA. Here is a screen shot.
barbours
Post by barbours »
As part of the modification, you also get a new or additional search function that includes the download function.
