Anacron Job error: gzip: /etc/MailScanner/phishing.safe.sites.conf.master.gz: unexpected end of file
ericarcher57
Post by ericarcher57 »
Been getting repeated errors for the daily Anacron job:
gzip: /etc/MailScanner/phishing.safe.sites.conf.master.gz: unexpected end of file.
Any Ideas on how to resolve?
Re: Anacron Job error: gzip: /etc/MailScanner/phishing.safe.sites.conf.master.gz: unexpected end of file
Have you tried deleting the file and letting it run again?
BOOZy
Post by BOOZy »
Getting this error as well lately.
If you open the phishing.safe.sites.conf.master.gz file in a text editor it reads: 301 Moved Permanently (surrounded by some html).
So it seems the file has moved to another url and the script that downloads it doesn't understand the redirect and instead downloads the html.
Pukkeltje
Post by Pukkeltje »
I'm getting same kind of error:
/etc/cron.daily/mailscanner:
gzip: /etc/MailScanner/phishing.safe.sites.conf.master.gz: not in gzip format
Delete the file, should go away.
BOOZy
Post by BOOZy »
Deleting the file does indeed fix the issue. The next update cycle works as intended.
