A hard path to a successful migration...
Posted: 06 Aug 2024 07:57
Hi to all (and thanks to @shawnivertson, @pdwalker, @henk...)
I'm trying to migrate my working VM CentOS 7 + eFa v4 to AlmaLinux 9.4 + eFa v5
1)
https://wiki.efa-project.org/doku.php?id=setup_guide
It should be nice to update the information there, my feeling is that they are related to v4
2)
https://wiki.efa-project.org/doku.php?i ... tion_guide
"v4 Appliance Preparation
sudo sa-learn –backup > /root/backup.txt"
I'm getting this:
sudo su -
to work as root; now, I'm getting this:
Any hint? Thank you...
1)
2)
I'm getting this:
So, I've issued a[admin@efa4 ~]$ sudo sa-learn --backup > /root/backup.txt
-bash: /root/backup.txt: Permesso negato (-->Permission denied)
sudo su -
Searching through the forum, I've found a thread about that error, but the fix was related to eFa v3, so it's not applicable...[root@efa4 ~]# sa-learn --backup > /root/backup.txt
ERROR: Bayes backup returned an error, please re-run with -D for more information
re-issued with -D switch:
[root@efa4 ~]# sa-learn --backup -D > /root/backup.txt
Aug 6 09:36:44.441 [2055] dbg: logger: adding facilities: all
Aug 6 09:36:44.441 [2055] dbg: logger: logging level is DBG
Aug 6 09:36:44.441 [2055] dbg: generic: SpamAssassin version 3.4.6
Aug 6 09:36:44.441 [2055] dbg: generic: Perl 5.016003, PREFIX=/usr, DEF_RULES_DIR=/usr/share/spamassassin, LOCAL_RULES_DIR=/etc/mail/spamassassin, LOCAL_STATE_DIR=/var/lib/spamassassin
Aug 6 09:36:44.441 [2055] dbg: config: timing enabled
Aug 6 09:36:44.442 [2055] dbg: config: score set 0 chosen.
Aug 6 09:36:44.443 [2055] dbg: util: running in taint mode? yes
Aug 6 09:36:44.443 [2055] dbg: util: taint mode: deleting unsafe environment variables, resetting PATH
Aug 6 09:36:44.443 [2055] dbg: util: PATH included '/usr/local/sbin', keeping
Aug 6 09:36:44.443 [2055] dbg: util: PATH included '/usr/local/bin', keeping
Aug 6 09:36:44.443 [2055] dbg: util: PATH included '/sbin', keeping
Aug 6 09:36:44.443 [2055] dbg: util: PATH included '/bin', keeping
Aug 6 09:36:44.443 [2055] dbg: util: PATH included '/usr/sbin', keeping
Aug 6 09:36:44.443 [2055] dbg: util: PATH included '/usr/bin', keeping
Aug 6 09:36:44.443 [2055] dbg: util: PATH included '/root/bin', which is unusable, dropping: File o directory non esistente
Aug 6 09:36:44.443 [2055] dbg: util: final PATH set to: /usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
Aug 6 09:36:44.446 [2055] dbg: config: using "/etc/mail/spamassassin" for site rules pre files
Aug 6 09:36:45.855 [2055] dbg: dns: EDNS, UDP payload size 4096
Aug 6 09:36:45.855 [2055] dbg: dns: servers set by config to: [127.0.0.1]:53
Aug 6 09:36:45.856 [2055] dbg: dns: nameservers set to 127.0.0.1
Aug 6 09:36:45.856 [2055] dbg: dns: using socket module: IO::Socket::IP version 0.21
Aug 6 09:36:45.856 [2055] dbg: dns: is Net::DNS::Resolver available? yes
Aug 6 09:36:45.856 [2055] dbg: dns: Net::DNS version: 0.72
Aug 6 09:36:45.856 [2055] dbg: sa-learn: spamtest initialized
Aug 6 09:36:45.858 [2055] dbg: bayes: unable to connect to database: Access denied for user 'sa_user'@'localhost' (using password: YES)
Aug 6 09:36:45.858 [2055] dbg: plugin: Mail::SpamAssassin::Plugin::Bayes=HASH(0x3e4a550) implements 'learner_close', priority 0
Aug 6 09:36:45.858 [2055] dbg: plugin: Mail::SpamAssassin::Plugin::TxRep=HASH(0x427ba58) implements 'learner_close', priority 0
Aug 6 09:36:45.858 [2055] dbg: TxRep: learner_close
