Hi I noticed that the GUI was 1 hour in front of the actual time here in the UK, I have SSH'd to my EFA and have corrected the timezone on the console to be Europe/UK rather than CET, rebooted and it still showing the correct time. However when I look at the GUI again its still one hour ahead, does the GUI have a timezone setting in it?
Will
Time Keeping
Re: Time Keeping
Hi Will,
Yes baruwa also has a timezone setting:
edit /etc/baruwa/settings.py and find the 'TIME_ZONE' setting.
I will also try to add this to the EFA-Configure script so that can be used to configure the time zone.
Re: Time Keeping
Thanks Darky
Will edit it now.
Regards
Will
Will edit it now.
Regards
Will
