recent/searchreports seems intermittent (missing emails)
Posted: 27 Jun 2024 23:45
by itgandhdental
trying to get this sorted, not all emails are showing in recent messages, and when I use the search feature they're also missing, so it appears they're not getting logged by EFA, however the email does show scanned and believed to be clean, so SA/mailscanner is working? but recent messages is just overlooking others? I don't get it. there was one thread where it was suggested to clean the mariaDB and whatnot, I ran that, got rid of 46k records, but does not appear to have helped. Looking for some extra help here.
MailWatch Version: 1.2.18
Operating System Version: CentOS Stream 8
Postfix Version: 3.5.9
MailScanner Version: 5.5.1
ClamAV Version: 0.103.10
SpamAssassin Version: 3.4.6
PHP Version: 7.2.24
MySQL Version: 10.3.28-MariaDB
GeoIP Database Version: GeoLite2 Country database 2018-06-07 13:38:29
MailWatch for MailScanner v1.2.18 running on eFa-4.0.4 - © 2006-2024
Re: recent/searchreports seems intermittent (missing emails)
Posted: 29 Jun 2024 20:28
itgandhdental wrote: 27 Jun 2024 23:45
Are you up to date? The current version of MailWatch is 1.2.23. There are a lot of fixes in MailWatch, including those for logging.
Posted: 01 Jul 2024 18:29
by itgandhdental
currently out of date, and just noticed option 13 is not working, Error: failed to download metadata for repo 'appstream' no URLs in mirror list.
so looks like I've got a different issue to take care of first, then worry about the missing emails in the logs.
Posted: 11 Jul 2024 02:03
by itgandhdental
ok patching everything now, first steps
https://phoenixnap.com/kb/migrate-cento ... tos-stream
to migrate to stream, the dnf update failed so I had to point it to the new repos, then update from there. all appears well.
Update now, are you sure? (y/N): y
Last metadata expiration check: 0:16:44 ago on Wed 10 Jul 2024 06:43:48 PM PDT.
Dependencies resolved.
Nothing to do.
Complete!
Software Versions
MailWatch Version: 1.2.23
Postfix Version: 3.5.23
ClamAV Version: 0.103.11
PHP Version: 7.2.24
MySQL Version: 5.5.5-10.3.28-MariaDB
I do believe the issue has been addressed.
