Update SA manually
xydeown
Update SA manually
Post by xydeown »
Can I update SA manually without causing any issues?
I'm currently using EFA 5 beta, but I would like to upgrade to the latest SA 4.0.0.1 with the recent fixes.
Thank you.
Re: Update SA manually
eFa 5.0.0-6 has SA 4.0.1:
rpm -qa | grep spamassassin
spamassassin-4.0.1-2.eFa.el9.x86_64
