When installing on a clean Rocky 9.3 this error occurs.
Someone else had the same issue also on AlmaLinux 9.
When I tried to install EFA5 with the option dev:
sudo bash build.bash dev
Option in menu to activate webmin does not work btw.
But I can install this manually as I did before on EFA4 long before it was integrated.
