3.0.4 Sa-Update
buzzzo
3.0.4 Sa-Update
Post by buzzzo »
Regarding EFA-SA-Update, i see in the update to 3.0.4 script:
#Issue #65 Fix EFA-SA-Update file location
rm -f /etc/cron.daily/EFA-SA-Update
rm -f /usr/local/sbin/EFA-SA-Update
/usr/bin/wget -O /usr/local/sbin/EFA-SA-Update $gitdlurl/$VERSION/build/EFA/EFA-SA-Update
chmod 755 /usr/local/sbin/EFA-SA-Update
But in cron.daily i don't see any symlink pointing to /usr/local/sbin/EFA-SA-Update, so the script will actually never run
Is it a wanted solution or a bug ?
Thx
darky83
Site Admin
Re: 3.0.4 Sa-Update
Post by darky83 »
It is called from EFA-Daily-cron:
/etc/cron.daily/EFA-Daily-cron
