NDR / Notify Senders
xware
Post by xware »
i am having an issue when a user INSIDE my org sends a message that gets blocked. they are not notified in any way and just seems to them like the email got delivered.
i have Notify Senders set to yes.
for instance, some users have been sending converted xls file as pdfs but the file name shows filename.xls.pdf so the email is blocked by efa project because it thinks they are trying to disguised an xls file.
the issue is that the sender INSIDE my org is never notified that the email was blocked. is there something I'm missing?
Re: NDR / Notify Senders
Is this also set?
Notify Senders Of Blocked Filenames Or Filetypes = yes
xware
Post by xware »
it is
# Notifications back to the senders of blocked messages
# Do you want to notify the people who sent you messages containing
# viruses or badly-named filenames?
Notify Senders = yes
# *If* "Notify Senders" is set to yes, do you want to notify people
# who sent you messages containing viruses?
# The default value has been changed to "no" as most viruses now fake
# sender addresses and therefore should be on the "Silent Viruses" list.
Notify Senders Of Viruses = yes
# who sent you messages containing attachments that are blocked due to
# their filename or file contents?
# being too small or too large?
Notify Senders Of Blocked Size Attachments = yes
# who sent you messages containing other blocked content, such as
# partial messages or messages with external bodies?
Notify Senders Of Other Blocked Content = yes
# If you supply a space-separated list of message "precedence" settings,
# then senders of those messages will not be warned about anything you
# rejected. This is particularly suitable for mailing lists, so that any
# MailScanner responses do not get sent to the entire list.
Never Notify Senders Of Precedence = list bulk
