Efa 4.0.4 - 41 -
Posted: 23 Feb 2024 10:26
				Hi ,
Afer install update to Efa 4.0.4- 41 i have problem witch 451 4.7.1 Service unavailable - try again later; Of course before working OK.
I check the logs :
Feb 2 19:20:14 mx4 postfix/smtpd[85109]: connect from FQDN[X.X.X.X]
Feb 2 19:20:14 mx4 postfix/smtpd[85109]: match_list_match: FQDN: no match
Feb 2 19:20:14 mx4 postfix/smtpd[85109]: milter_macro_lookup: result "FQDN [X.X.X.X]"
Feb 2 19:20:14 mx4 postfix/smtpd[85109]: milter8_conn_event: milter inet:127.0.0.1:8891: connect FQDN/X.X.X.X
Feb 2 19:20:14 mx4 postfix/smtpd[85109]: event: SMFIC_CONNECT; macros: j=mx {daemon_name}=mx {daemon_addr}=10.10.1.24 v=Postfix 3.5.9 _=FQDN [X.X.X.X]
Feb 2 19:20:14 mx4 postfix/smtpd[85109]: milter8_conn_event: milter inet:127.0.0.1:8893: connect FQDN/X.X.X.X
Feb 2 19:20:14 mx4 postfix/smtpd[85109]: > FQDN[X.X.X.X]: 220 mx ESMTP Postfix
Feb 2 19:20:14 mx4 postfix/smtpd[85109]: < FQDN[X.X.X.X]: EHLO FQDN
Feb 2 19:20:14 mx4 postfix/smtpd[85109]: milter8_helo_event: milter inet:127.0.0.1:8891: helo FQDN
Feb 2 19:20:14 mx4 postfix/smtpd[85109]: milter8_helo_event: milter inet:127.0.0.1:8893: helo FQDN
 helo FQDN
Feb 2 19:20:14 mx4 postfix/smtpd[85109]: NOQUEUE: milter-reject: EHLO from FQDN[X.X.X.X]: 451 4.7.1 Service unavailable - try again later; proto=SMTP helo=<FQDN>
Feb 2 19:20:14 mx4 postfix/smtpd[85109]: > FQDN[X.X.X.X]: 250-mx
Feb 2 19:20:14 mx4 postfix/smtpd[85109]: > FQDN[X.X.X.X]: 250-PIPELINING
Feb 2 19:20:14 mx4 postfix/smtpd[85109]: > FQDN[X.X.X.X]: 250-SIZE 133169152
Feb 2 19:20:14 mx4 postfix/smtpd[85109]: > FQDN[X.X.X.X]: 250-ETRN
Feb 2 19:20:14 mx4 postfix/smtpd[85109]: > FQDN[X.X.X.X]: 250-STARTTLS
Feb 2 19:20:14 mx4 postfix/smtpd[85109]: > FQDN[X.X.X.X]: 250-ENHANCEDSTATUSCODES
Feb 2 19:20:14 mx4 postfix/smtpd[85109]: > FQDN[X.X.X.X]: 250-8BITMIME
Feb 2 19:20:14 mx4 postfix/smtpd[85109]: > FQDN[X.X.X.X]: 250-DSN
Feb 2 19:20:14 mx4 postfix/smtpd[85109]: > FQDN[X.X.X.X]: 250 SMTPUTF8
Feb 2 19:20:14 mx4 postfix/smtpd[85109]: < FQDN[X.X.X.X]: STARTTLS
Feb 2 19:20:14 mx4 postfix/smtpd[85109]: > FQDN[X.X.X.X]: 454 4.3.0 Try again later
Feb 2 19:20:14 mx4 postfix/smtpd[85109]: < FQDN[X.X.X.X]: MAIL FROM:<X@X.com>
Feb 2 19:20:14 mx4 postfix/smtpd[85109]: NOQUEUE: milter-reject: MAIL from FQDN[X.X.X.X]: 451 4.7.1 Service unavailable - try again later; from=<X@X.com> proto=ESMTP helo=<FQDN>
Feb 2 19:20:14 mx4 postfix/smtpd[85109]: > FQDN[X.X.X.X]: 451 4.7.1 Service unavailable - try again later
I search info about this and I find the problem in opendkim/opendmarc , but the version have fix this problem. I used :
libopendmarc-1.4.1.1-3.el7.x86_64
How I Can debug this problem and resolve this ?
Thanks for help
I check the logs :
Thanks for help
