I am having trouble installing eFa4 since last Monday (01/01/2024).
I have just installed a new Centos 7 Gnome complete and ran the install command "curl -sSL https://install.efa-project.org | bash" as I have always done before, however it stops with the following error:
2024.01.04-12:03:04 - ============= EFA4 BUILD SCRIPT STARTING ============
2024.01.04-12:03:04 - Good you are root.
2024.01.04-12:03:04 - Good you are running CentOS 7
2024.01.04-12:03:04 - Checking network connectivity
2024.01.04-12:03:04 - OK - https://mirrors.efa-project.org is reachable
2024.01.04-12:03:04 - Updating the OS
2024.01.04-12:03:43 - Removing conflicting packages
2024.01.04-12:03:44 - Installing eFa packages (This can take a while)
2024.01.04-12:04:26 - ERROR: eFa4 failed to install
2024.01.04-12:04:26 - ^^^^^^^^^^ SCRIPT ABORTED ^^^^^^^^^^
Is this a bug in the install? has something changed in the repo that is not agreeing with the install script?
