message marked as spam gives a razor error
doggy101
Post by doggy101 »
When I want to mark a message as spam i get:
SpamAssassin: Mar 15 16:18:59.561 [26903] warn: reporter: razor2 report failed: No such file or directory report requires authentication at /usr/local/share/perl5/Mail/SpamAssassin/Plugin/Razor2.pm line 180. at /usr/local/share/perl5/Mail/SpamAssassin/Plugin/Razor2.pm line 330., 1 message(s) examined.
Error: N
anyone any clue?
Re: message marked as spam gives a razor error
Hmm....this may be related to a postfix update that occurred.
Try this and report the results please
mkdir /var/spool/postfix/.razor
chown postfix:postfix /var/spool/postfix/.razor
doggy101
Post by doggy101 »
when creating the dir it say's it's allready there, with the chown no error
I will test further... and post results here
doggy101
Post by doggy101 »
No Problem still there
SpamAssassin: Mar 21 11:27:29.430 [5727] warn: reporter: razor2 report failed: No such file or directory report requires authentication at /usr/local/share/perl5/Mail/SpamAssassin/Plugin/Razor2.pm line 180. at /usr/local/share/perl5/Mail/SpamAssassin/Plugin/Razor2.pm line 330., 1 message(s) examined.
Error: N
Let's reregister razor...
sudo su postfix -s /bin/bash -c 'razor-admin -register'
doggy101
Post by doggy101 »
Nope still no luck....
bash: razor-admin: command not found
doggy101,
Is this a stock build of EFA or a build from scratch?
Try both of these:
su postfix -s /bin/bash -c 'razor-admin -create'
Antiloop
Post by Antiloop »
I have the same error:
SpamAssassin: Mar 27 23:22:33.586 [25024] warn: reporter: razor2 report failed: No such file or directory report requires authentication at /usr/local/share/perl5/Mail/SpamAssassin/Plugin/Razor2.pm line 180. at /usr/local/share/perl5/Mail/SpamAssassin/Plugin/Razor2.pm line 330., 1 message(s) examined.
I have tried the suggestions of shawn but these do not solve the problem
btw, I'm using EFA from the ISO (the kickstart file has some errors regarding to https download and a wrong ssl cert.)
doggy101
Post by doggy101 »
shawniverson wrote:doggy101,
what do you mean by that, it's a VM which i'm using...
Ok. Now, out of curiosity, what is the name of the user you set up when you first powered on the VM?
If anyone with this problem is interested, PM me. I would like to connect to your system remotely and see if I can help.
Michaelv
Post by Michaelv »
Also have the same problem.
Did you find out what happened to the other guy's vm?
Regards,
Michael
Negative. I am soliciting for remote access to a system to try to identify the problem.
knutz
Post by knutz »
I could provide access to a system that has this problem. But having just joined the forum I cannot PM you. I did send you an email.
Maybe if you PM me I will be able to respond.
Regards
Michaelv
Post by Michaelv »
Sent a PM to shawn for my test relay ip and credentials.
Regards,
Michael
Bug identified and resolved.
This fix will give Apache access to Razor credentials so that Spamassassin can submit reports....
sudo ln -s /var/spool/postfix/.razor /var/www/.razor
sudo chown -R postfix:apache /var/spool/postfix/.razor
sudo chmod ug+rwx /var/spool/postfix/.razor
sudo chmod ug+rw /var/spool/postfix/.razor/*
knutz
Post by knutz »
The errors have gone.
Michaelv
Post by Michaelv »
Yes I too concur the bug is gone.
doggy101
Post by doggy101 »
unfortunality the error is still there...
SpamAssassin: May 23 10:51:22.249 [3965] warn: reporter: razor2 report failed: No such file or directory report requires authentication at /usr/local/share/perl5/Mail/SpamAssassin/Plugin/Razor2.pm line 180. at /usr/local/share/perl5/Mail/SpamAssassin/Plugin/Razor2.pm line 330., 1 message(s) examined.
Was it gone for a while and then reappeared?
doggy101
Post by doggy101 »
as far as i know it has been there the whole time, today i changed the setup as described above.
darky83
Site Admin
Post by darky83 »
Added the fix to the 3.0.0.5 release
axered
Post by axered »
FYI, I installed the latest version 3.0.0.5 from scratch on hypervisor, XenServer 6.2, and when reported emails a Spam+Report, I got the errors from this post.
But running these commands below, that was provided on this post, did solve the problem.
