permissions on postfix folders
doggy101
Post by doggy101 »
Hi All,
in the EFA webinterface I see the following:
Please verify read permissions on /var/spool/postfix/hold and /var/spool/postfix/incoming.
what are they supposed to be?
tjg88
Re: permissions on postfix folders
Post by tjg88 »
I had this problem too, see this post, towards the end:
http://forum.efa-project.org/viewtopic.php?f=5&t=487
This is fixed in the 3.0.0.3 update. Update to receive the latest fixes. :whistle:
doggy101
Post by doggy101 »
okay will do...
buzzzo
Post by buzzzo »
or you could do from shell:
chown postfix:apache /var/spool/postfix/incoming
chown postfix:apache /var/spool/postfix/hold
chmod 740 /var/spool/postfix/incoming
chmod 740 /var/spool/postfix/hold
