My original system is CentOS Linux release 7.9.2009 running eFA 4.0.4-40 and my new system is Rocky Linux release 8.8. I fail on reboot with
[FAILED] Failed to start MariaDB 10.3 database server.
See 'systemctl status mariadb.service' for details.
[psmode@ballantine ~]$ sudo systemctl status mariadb.service
● mariadb.service - MariaDB 10.3 database server
Loaded: loaded (/usr/lib/systemd/system/mariadb.service; enabled; vendor preset: disabled)
Drop-In: /etc/systemd/system/mariadb.service.d
└─limit.conf, override.conf
Active: failed (Result: exit-code) since Fri 2023-07-14 09:16:01 EDT; 50s ago
Docs: man:mysqld(8)
https://mariadb.com/kb/en/library/systemd/
Process: 3824 ExecStart=/usr/libexec/mysqld --basedir=/usr $MYSQLD_OPTS $_WSREP_NEW_CLUSTER (code=exited, status=1/FAILURE)
Process: 3786 ExecStartPre=/usr/libexec/mysql-prepare-db-dir mariadb.service (code=exited, status=0/SUCCESS)
Process: 3761 ExecStartPre=/usr/libexec/mysql-check-socket (code=exited, status=0/SUCCESS)
Main PID: 3824 (code=exited, status=1/FAILURE)
Jul 14 09:16:01 ballantine.kitsnet.us systemd[1]: Starting MariaDB 10.3 database server...
Jul 14 09:16:01 ballantine.kitsnet.us mysql-prepare-db-dir[3786]: Database MariaDB is probably initialized in /var/lib/mysql already, nothing is done.
Jul 14 09:16:01 ballantine.kitsnet.us mysql-prepare-db-dir[3786]: If this is not the case, make sure the /var/lib/mysql is empty before running mysql-prepare-db-dir.
Jul 14 09:16:01 ballantine.kitsnet.us mysqld[3824]: 2023-07-14 9:16:01 0 [Note] /usr/libexec/mysqld (mysqld 10.3.35-MariaDB) starting as process 3824 ...
Jul 14 09:16:01 ballantine.kitsnet.us systemd[1]: mariadb.service: Main process exited, code=exited, status=1/FAILURE
Jul 14 09:16:01 ballantine.kitsnet.us systemd[1]: mariadb.service: Failed with result 'exit-code'.
Jul 14 09:16:01 ballantine.kitsnet.us systemd[1]: Failed to start MariaDB 10.3 database server.Code: Select all
Beginning Restore of /var/eFa/backup/backup-20230713-064451.tar.gz...
./backup/
./backup/sql/
./backup/sql/backup.sql
./backup/etc/
./backup/etc/postfix/
./backup/etc/postfix/ssl/
./backup/etc/postfix/ssl/dhparam.pem
./backup/etc/postfix/ssl/smtpd.pem
./backup/etc/postfix/dynamicmaps.cf
./backup/etc/postfix/main.cf
./backup/etc/postfix/master.cf
./backup/etc/postfix/access
./backup/etc/postfix/helo_access
./backup/etc/postfix/recipient_access
./backup/etc/postfix/sender_access
./backup/etc/postfix/canonical
./backup/etc/postfix/recipient_canonical
./backup/etc/postfix/sender_canonical
./backup/etc/postfix/transport
./backup/etc/postfix/virtual
./backup/etc/postfix/sasl_passwd
./backup/etc/postfix/relocated
./backup/etc/postfix/generic
./backup/etc/postfix/header_checks
./backup/etc/eFa/
./backup/etc/eFa/eFa-Config
./backup/etc/eFa/MailWatch-Config
./backup/etc/eFa/MySQL-Config
./backup/etc/eFa/openDMARC-Config
./backup/etc/eFa/SA-Config
./backup/etc/eFa/SQLGrey-Config
./backup/etc/sysconfig/
./backup/etc/sysconfig/anaconda
./backup/etc/sysconfig/authconfig
./backup/etc/sysconfig/cbq/
./backup/etc/sysconfig/cbq/avpkt
./backup/etc/sysconfig/cbq/cbq-0000.example
./backup/etc/sysconfig/certbot
./backup/etc/sysconfig/chronyd
./backup/etc/sysconfig/console/
./backup/etc/sysconfig/cpupower
./backup/etc/sysconfig/crond
./backup/etc/sysconfig/daemons/
./backup/etc/sysconfig/daemons/webmin
./backup/etc/sysconfig/ebtables-config
./backup/etc/sysconfig/eFa-Monitor
./backup/etc/sysconfig/firewalld
./backup/etc/sysconfig/freshclam
./backup/etc/sysconfig/grub
./backup/etc/sysconfig/htcacheclean
./backup/etc/sysconfig/httpd
./backup/etc/sysconfig/init
./backup/etc/sysconfig/ip6tables-config
./backup/etc/sysconfig/iptables
./backup/etc/sysconfig/iptables-config
./backup/etc/sysconfig/irqbalance
./backup/etc/sysconfig/kdump
./backup/etc/sysconfig/kernel
./backup/etc/sysconfig/man-db
./backup/etc/sysconfig/modules/
./backup/etc/sysconfig/netconsole
./backup/etc/sysconfig/network
./backup/etc/sysconfig/network-scripts/
./backup/etc/sysconfig/network-scripts/ifcfg-lo
./backup/etc/sysconfig/network-scripts/ifdown
./backup/etc/sysconfig/network-scripts/ifdown-bnep
./backup/etc/sysconfig/network-scripts/ifdown-eth
./backup/etc/sysconfig/network-scripts/ifdown-ippp
./backup/etc/sysconfig/network-scripts/ifdown-ipv6
./backup/etc/sysconfig/network-scripts/ifdown-isdn
./backup/etc/sysconfig/network-scripts/ifdown-post
./backup/etc/sysconfig/network-scripts/ifdown-ppp
./backup/etc/sysconfig/network-scripts/ifdown-routes
./backup/etc/sysconfig/network-scripts/ifdown-sit
./backup/etc/sysconfig/network-scripts/ifdown-tunnel
./backup/etc/sysconfig/network-scripts/ifup
./backup/etc/sysconfig/network-scripts/ifup-aliases
./backup/etc/sysconfig/network-scripts/ifup-bnep
./backup/etc/sysconfig/network-scripts/ifup-eth
./backup/etc/sysconfig/network-scripts/ifup-ippp
./backup/etc/sysconfig/network-scripts/ifup-ipv6
./backup/etc/sysconfig/network-scripts/ifup-isdn
./backup/etc/sysconfig/network-scripts/ifup-plip
./backup/etc/sysconfig/network-scripts/ifup-plusb
./backup/etc/sysconfig/network-scripts/ifup-post
./backup/etc/sysconfig/network-scripts/ifup-ppp
./backup/etc/sysconfig/network-scripts/ifup-routes
./backup/etc/sysconfig/network-scripts/ifup-sit
./backup/etc/sysconfig/network-scripts/ifup-tunnel
./backup/etc/sysconfig/network-scripts/ifup-wireless
./backup/etc/sysconfig/network-scripts/init.ipv6-global
./backup/etc/sysconfig/network-scripts/network-functions
./backup/etc/sysconfig/network-scripts/network-functions-ipv6
./backup/etc/sysconfig/network-scripts/ifdown-Team
./backup/etc/sysconfig/network-scripts/ifdown-TeamPort
./backup/etc/sysconfig/network-scripts/ifup-Team
./backup/etc/sysconfig/network-scripts/ifup-TeamPort
./backup/etc/sysconfig/network-scripts/ifcfg-eth0
./backup/etc/sysconfig/network-scripts.bak/
./backup/etc/sysconfig/network-scripts.bak/ifcfg-eth0.bak
./backup/etc/sysconfig/nfs
./backup/etc/sysconfig/opendkim
./backup/etc/sysconfig/opendmarc
./backup/etc/sysconfig/qemu-ga
./backup/etc/sysconfig/rdisc
./backup/etc/sysconfig/readonly-root
./backup/etc/sysconfig/rpcbind
./backup/etc/sysconfig/rpc-rquotad
./backup/etc/sysconfig/rsyslog
./backup/etc/sysconfig/run-parts
./backup/etc/sysconfig/saslauthd
./backup/etc/sysconfig/selinux
./backup/etc/sysconfig/sshd
./backup/etc/sysconfig/sysstat
./backup/etc/sysconfig/sysstat.ioconf
./backup/etc/sysconfig/unbound
./backup/etc/sysconfig/wpa_supplicant
./backup/etc/passwd
./backup/etc/fstab
./backup/etc/shadow
./backup/etc/clamd.d/
./backup/etc/clamd.d/scan.conf
./backup/etc/hosts
./backup/etc/hosts.allow
./backup/etc/hosts.deny
./backup/etc/networks
./backup/etc/my.cnf
./backup/etc/my.cnf.d/
./backup/etc/my.cnf.d/client.cnf
./backup/etc/my.cnf.d/enable_encryption.preset
./backup/etc/my.cnf.d/mariadb-server.cnf
./backup/etc/my.cnf.d/mariadb-server.cnf.rpmnew
./backup/etc/my.cnf.d/mysql-clients.cnf
./backup/etc/php.ini
./backup/etc/php-fpm.conf
./backup/etc/php-fpm.d/
./backup/etc/php-fpm.d/www.conf
./backup/etc/resolv.conf
./backup/etc/resolv.conf.SAFETY
./backup/etc/sudo.conf
./backup/etc/sudoers.d/
./backup/etc/sudoers.d/eFa-Services
./backup/etc/sudoers.d/eFa-users
./backup/etc/sudoers.d/mailwatch
./backup/etc/MailScanner/
./backup/etc/MailScanner/archives.filename.rules
./backup/etc/MailScanner/archives.filename.rules.allowall.conf
./backup/etc/MailScanner/archives.filename.rules.conf
./backup/etc/MailScanner/archives.filetype.rules
./backup/etc/MailScanner/archives.filetype.rules.allowall.conf
./backup/etc/MailScanner/archives.filetype.rules.conf
./backup/etc/MailScanner/conf.d/
./backup/etc/MailScanner/conf.d/README
./backup/etc/MailScanner/country.domains.conf
./backup/etc/MailScanner/custom
./backup/etc/MailScanner/defaults
./backup/etc/MailScanner/defaults.rpmnew
./backup/etc/MailScanner/filename.rules
./backup/etc/MailScanner/filename.rules.allowall.conf
./backup/etc/MailScanner/filename.rules.conf
./backup/etc/MailScanner/filetype.rules
./backup/etc/MailScanner/filetype.rules.allowall.conf
./backup/etc/MailScanner/filetype.rules.conf
./backup/etc/MailScanner/MailScanner.conf
./backup/etc/MailScanner/mcp/
./backup/etc/MailScanner/mcp/10_example.cf
./backup/etc/MailScanner/mcp/mcp.spamassassin.conf
./backup/etc/MailScanner/mcp/init.pre
./backup/etc/MailScanner/mcp/v310.pre
./backup/etc/MailScanner/mcp/v312.pre
./backup/etc/MailScanner/mcp/v320.pre
./backup/etc/MailScanner/mcp/v330.pre
./backup/etc/MailScanner/mcp/v340.pre
./backup/etc/MailScanner/mcp/v341.pre
./backup/etc/MailScanner/mcp/v342.pre
./backup/etc/MailScanner/numeric.phishing.rules
./backup/etc/MailScanner/phishing.bad.sites.conf
./backup/etc/MailScanner/phishing.bad.sites.conf.master
./backup/etc/MailScanner/phishing.bad.sites.conf.master.backup
./backup/etc/MailScanner/phishing.bad.sites.custom
./backup/etc/MailScanner/phishing.safe.sites.conf
./backup/etc/MailScanner/phishing.safe.sites.conf.master
./backup/etc/MailScanner/phishing.safe.sites.conf.master.backup
./backup/etc/MailScanner/phishing.safe.sites.custom
./backup/etc/MailScanner/reports
./backup/etc/MailScanner/rules/
./backup/etc/MailScanner/rules/EXAMPLES
./backup/etc/MailScanner/rules/README
./backup/etc/MailScanner/rules/bounce.rules
./backup/etc/MailScanner/rules/external.message.rules
./backup/etc/MailScanner/rules/max.message.size.rules
./backup/etc/MailScanner/rules/spam.whitelist.rules
./backup/etc/MailScanner/rules/spam.blacklist.rules
./backup/etc/MailScanner/rules/sig.html.rules
./backup/etc/MailScanner/rules/sig.text.rules
./backup/etc/MailScanner/rules/content.scanning.rules
./backup/etc/MailScanner/rules/password.rules
./backup/etc/MailScanner/spamassassin.conf
./backup/etc/MailScanner/spamassassin.conf.bak
./backup/etc/MailScanner/spamassassin.conf.rpmnew
./backup/etc/MailScanner/spam.lists.conf
./backup/etc/MailScanner/virus.scanners.conf
./backup/etc/cron.d/
./backup/etc/cron.d/0hourly
./backup/etc/cron.d/sysstat
./backup/etc/cron.d/msre_reload
./backup/etc/cron.d/clamav-update
./backup/etc/cron.d/checkreboot
./backup/etc/cron.d/eFa-Monitor.cron
./backup/etc/cron.daily/
./backup/etc/cron.daily/logrotate
./backup/etc/cron.daily/man-db.cron
./backup/etc/cron.daily/0logwatch
./backup/etc/cron.daily/0yum-daily.cron
./backup/etc/cron.daily/mailscanner
./backup/etc/cron.daily/mailwatch
./backup/etc/cron.daily/eFa-Backup.cron
./backup/etc/cron.daily/trim-txrep
./backup/etc/cron.daily/eFa-SAClean
./backup/etc/cron.daily/cron-dccd
./backup/etc/cron.daily/eFa-Daily-DMARC
./backup/etc/cron.daily/eFa-Tokens.cron
./backup/etc/cron.deny
./backup/etc/cron.hourly/
./backup/etc/cron.hourly/0anacron
./backup/etc/cron.hourly/0yum-hourly.cron
./backup/etc/cron.hourly/mailscanner
./backup/etc/cron.monthly/
./backup/etc/cron.monthly/mailwatch
./backup/etc/crontab
./backup/etc/cron.weekly/
./backup/etc/cron.weekly/eFa-Weekly-DMARC
./backup/etc/sqlgrey/
./backup/etc/sqlgrey/clients_fqdn_whitelist
./backup/etc/sqlgrey/clients_fqdn_whitelist.local
./backup/etc/sqlgrey/clients_ip_whitelist
./backup/etc/sqlgrey/clients_ip_whitelist.local
./backup/etc/sqlgrey/discrimination.regexp
./backup/etc/sqlgrey/dyn_fqdn.regexp
./backup/etc/sqlgrey/README
./backup/etc/sqlgrey/smtp_server.regexp
./backup/etc/sqlgrey/sqlgrey.conf
./backup/etc/ssh/
./backup/etc/ssh/moduli
./backup/etc/ssh/ssh_config
./backup/etc/ssh/sshd_config
./backup/etc/ssh/ssh_host_dsa_key
./backup/etc/ssh/ssh_host_dsa_key.pub
./backup/etc/ssh/ssh_host_ecdsa_key
./backup/etc/ssh/ssh_host_ecdsa_key.pub
./backup/etc/ssh/ssh_host_ed25519_key
./backup/etc/ssh/ssh_host_ed25519_key.pub
./backup/etc/ssh/ssh_host_rsa_key
./backup/etc/ssh/ssh_host_rsa_key.pub
./backup/etc/pki/
./backup/etc/pki/CA/
./backup/etc/pki/CA/certs/
./backup/etc/pki/CA/crl/
./backup/etc/pki/CA/newcerts/
./backup/etc/pki/CA/private/
./backup/etc/pki/ca-trust/
./backup/etc/pki/ca-trust/README
./backup/etc/pki/ca-trust/ca-legacy.conf
./backup/etc/pki/ca-trust/extracted/
./backup/etc/pki/ca-trust/extracted/README
./backup/etc/pki/ca-trust/extracted/java/
./backup/etc/pki/ca-trust/extracted/java/README
./backup/etc/pki/ca-trust/extracted/java/cacerts
./backup/etc/pki/ca-trust/extracted/openssl/
./backup/etc/pki/ca-trust/extracted/openssl/README
./backup/etc/pki/ca-trust/extracted/openssl/ca-bundle.trust.crt
./backup/etc/pki/ca-trust/extracted/pem/
./backup/etc/pki/ca-trust/extracted/pem/README
./backup/etc/pki/ca-trust/extracted/pem/tls-ca-bundle.pem
./backup/etc/pki/ca-trust/extracted/pem/email-ca-bundle.pem
./backup/etc/pki/ca-trust/extracted/pem/objsign-ca-bundle.pem
./backup/etc/pki/ca-trust/source/
./backup/etc/pki/ca-trust/source/README
./backup/etc/pki/ca-trust/source/anchors/
./backup/etc/pki/ca-trust/source/blacklist/
./backup/etc/pki/ca-trust/source/ca-bundle.legacy.crt
./backup/etc/pki/dovecot/
./backup/etc/pki/dovecot/certs/
./backup/etc/pki/dovecot/certs/dovecot.pem
./backup/etc/pki/dovecot/dovecot-openssl.cnf
./backup/etc/pki/dovecot/private/
./backup/etc/pki/dovecot/private/dovecot.pem
./backup/etc/pki/java/
./backup/etc/pki/java/cacerts
./backup/etc/pki/nssdb/
./backup/etc/pki/nssdb/cert8.db
./backup/etc/pki/nssdb/cert9.db
./backup/etc/pki/nssdb/key3.db
./backup/etc/pki/nssdb/key4.db
./backup/etc/pki/nssdb/pkcs11.txt
./backup/etc/pki/nssdb/secmod.db
./backup/etc/pki/nssdb/dbTemp.pVdYcu/
./backup/etc/pki/nssdb/dbTemp.beKnS0/
./backup/etc/pki/nssdb/dbTemp.FCO2UK/
./backup/etc/pki/nssdb/dbTemp.zc6bUa/
./backup/etc/pki/nssdb/dbTemp.lBJLig/
./backup/etc/pki/nssdb/dbTemp.rOr8Ev/
./backup/etc/pki/nssdb/dbTemp.0u3Cju/
./backup/etc/pki/nss-legacy/
./backup/etc/pki/nss-legacy/nss-rhel7.config
./backup/etc/pki/rpm-gpg/
./backup/etc/pki/rpm-gpg/RPM-GPG-KEY-CentOS-7
./backup/etc/pki/rpm-gpg/RPM-GPG-KEY-CentOS-Debug-7
./backup/etc/pki/rpm-gpg/RPM-GPG-KEY-CentOS-Testing-7
./backup/etc/pki/rpm-gpg/RPM-GPG-KEY-EPEL-7
./backup/etc/pki/rpm-gpg/RPM-GPG-KEY-IUS-7
./backup/etc/pki/rpm-gpg/RPM-EFDCEA77
./backup/etc/pki/rpm-gpg/RPM-EFDCEA77.asc
./backup/etc/pki/rpm-gpg/RPM-GPG-KEY-ZABBIX
./backup/etc/pki/rpm-gpg/RPM-GPG-KEY-ZABBIX-A14FE591
./backup/etc/pki/rsyslog/
./backup/etc/pki/tls/
./backup/etc/pki/tls/cert.pem
./backup/etc/pki/tls/certs/
./backup/etc/pki/tls/certs/ca-bundle.crt
./backup/etc/pki/tls/certs/ca-bundle.trust.crt
./backup/etc/pki/tls/certs/Makefile
./backup/etc/pki/tls/certs/make-dummy-cert
./backup/etc/pki/tls/certs/renew-dummy-cert
./backup/etc/pki/tls/certs/localhost.crt
./backup/etc/pki/tls/misc/
./backup/etc/pki/tls/misc/CA
./backup/etc/pki/tls/misc/c_hash
./backup/etc/pki/tls/misc/c_info
./backup/etc/pki/tls/misc/c_issuer
./backup/etc/pki/tls/misc/c_name
./backup/etc/pki/tls/openssl.cnf
./backup/etc/pki/tls/private/
./backup/etc/pki/tls/private/localhost.key
./backup/etc/httpd/
./backup/etc/httpd/conf/
./backup/etc/httpd/conf/httpd.conf
./backup/etc/httpd/conf/magic
./backup/etc/httpd/conf.d/
./backup/etc/httpd/conf.d/README
./backup/etc/httpd/conf.d/userdir.conf
./backup/etc/httpd/conf.d/php.conf
./backup/etc/httpd/conf.d/ssl.conf
./backup/etc/httpd/conf.d/autoindex.conf.orig
./backup/etc/httpd/conf.d/redirectssl.conf
./backup/etc/httpd/conf.d/fpm.conf
./backup/etc/httpd/conf.d/welcome.conf
./backup/etc/httpd/conf.modules.d/
./backup/etc/httpd/conf.modules.d/00-base.conf
./backup/etc/httpd/conf.modules.d/00-dav.conf
./backup/etc/httpd/conf.modules.d/00-lua.conf
./backup/etc/httpd/conf.modules.d/00-mpm.conf
./backup/etc/httpd/conf.modules.d/00-optional.conf
./backup/etc/httpd/conf.modules.d/00-proxy.conf
./backup/etc/httpd/conf.modules.d/00-systemd.conf
./backup/etc/httpd/conf.modules.d/01-cgi.conf
./backup/etc/httpd/conf.modules.d/README
./backup/etc/httpd/conf.modules.d/15-php.conf
./backup/etc/httpd/conf.modules.d/00-ssl.conf
./backup/etc/httpd/logs
./backup/etc/httpd/modules
./backup/etc/httpd/run
./backup/etc/unbound/
./backup/etc/unbound/conf.d/
./backup/etc/unbound/conf.d/example.com.conf
./backup/etc/unbound/conf.d/forwarders.conf
./backup/etc/unbound/icannbundle.pem
./backup/etc/unbound/keys.d/
./backup/etc/unbound/keys.d/example.com.key
./backup/etc/unbound/local.d/
./backup/etc/unbound/local.d/block-example.com.conf
./backup/etc/unbound/root.key
./backup/etc/unbound/unbound.conf
./backup/etc/unbound/unbound.conf.rpmnew
./backup/etc/unbound/unbound_control.key
./backup/etc/unbound/unbound_control.pem
./backup/etc/unbound/unbound_server.key
./backup/etc/unbound/unbound_server.pem
./backup/etc/mail/
./backup/etc/mail/spamassassin/
./backup/etc/mail/spamassassin/local.cf
./backup/etc/opendkim/
./backup/etc/opendkim/keys/
./backup/etc/opendkim/KeyTable
./backup/etc/opendkim/SigningTable
./backup/etc/opendkim/TrustedHosts
./backup/etc/opendmarc.conf
./backup/etc/opendmarc/
./backup/etc/opendmarc/ignore.hosts
./backup/etc/opendmarc/public_suffix_list.dat
./backup/etc/opendmarc/public_suffix_list.dat.old
./backup/var/
./backup/var/www/
./backup/var/www/html/
./backup/var/www/html/mailscanner/
./backup/var/www/html/mailscanner/conf.php
Foreign backup detected, performing import...
postmap: warning: /etc/postfix/dynamicmaps.cf: file is owned or writable by non-root users -- skipping this file
postmap: warning: /etc/postfix/dynamicmaps.cf.d/cdb: file is owned or writable by non-root users -- skipping this file
postmap: warning: /etc/postfix/dynamicmaps.cf.d/ldap: file is owned or writable by non-root users -- skipping this file
postmap: warning: /etc/postfix/dynamicmaps.cf.d/mysql: file is owned or writable by non-root users -- skipping this file
postmap: warning: /etc/postfix/dynamicmaps.cf.d/pcre: file is owned or writable by non-root users -- skipping this file
postmap: warning: /etc/postfix/dynamicmaps.cf.d/pgsql: file is owned or writable by non-root users -- skipping this file
postmap: warning: /etc/postfix/dynamicmaps.cf.d/sqlite: file is owned or writable by non-root users -- skipping this file
Added new: Lockfile Dir = /var/spool/MailScanner/incoming/Locks
Added new: include /etc/MailScanner/conf.d/*
Summary
Read 393 settings from old /etc/MailScanner/MailScanner.conf.original
Used 392 settings from old /etc/MailScanner/MailScanner.conf.original
Used 3 default settings from new /etc/MailScanner/MailScanner.conf.restore
ERROR 1449 (HY000) at line 1: The user specified as a definer ('mariadb.sys'@'localhost') does not exist
ERROR 1347 (HY000) at line 1: 'mysql.user' is not of type 'TABLE'
Error: Database connection failed: it is possible that the database is overloaded or otherwise not running properly; contact the system administrator if the problem persists
shell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
Phase 1/7: Checking and upgrading mysql database
Processing databases
mysql
mysql.column_stats OK
mysql.columns_priv OK
mysql.db OK
mysql.event OK
mysql.func OK
mysql.global_priv OK
mysql.gtid_slave_pos OK
mysql.help_category OK
mysql.help_keyword OK
mysql.help_relation OK
mysql.help_topic OK
mysql.host OK
mysql.index_stats OK
mysql.innodb_index_stats OK
mysql.innodb_table_stats OK
mysql.plugin OK
mysql.proc OK
mysql.procs_priv OK
mysql.proxies_priv OK
mysql.roles_mapping OK
mysql.servers OK
mysql.table_stats OK
mysql.tables_priv OK
mysql.time_zone OK
mysql.time_zone_leap_second OK
mysql.time_zone_name OK
mysql.time_zone_transition OK
mysql.time_zone_transition_type OK
mysql.transaction_registry OK
Phase 2/7: Installing used storage engines... Skipped
Phase 3/7: Fixing views
mysql.user
Error : The user specified as a definer ('mariadb.sys'@'localhost') does not exist
error : Corrupt
Phase 4/7: Running 'mysql_fix_privilege_tables'
ERROR 1347 (HY000) at line 161: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1449 (HY000) at line 163: The user specified as a definer ('mariadb.sys'@'localhost') does not exist
ERROR 1347 (HY000) at line 164: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1449 (HY000) at line 176: The user specified as a definer ('mariadb.sys'@'localhost') does not exist
ERROR 1347 (HY000) at line 179: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1347 (HY000) at line 184: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1449 (HY000) at line 220: The user specified as a definer ('mariadb.sys'@'localhost') does not exist
ERROR 1347 (HY000) at line 221: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1449 (HY000) at line 229: The user specified as a definer ('mariadb.sys'@'localhost') does not exist
ERROR 1347 (HY000) at line 230: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1347 (HY000) at line 240: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1347 (HY000) at line 243: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1347 (HY000) at line 245: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1347 (HY000) at line 249: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1347 (HY000) at line 251: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1449 (HY000) at line 350: The user specified as a definer ('mariadb.sys'@'localhost') does not exist
ERROR 1347 (HY000) at line 355: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1347 (HY000) at line 356: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1347 (HY000) at line 361: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1347 (HY000) at line 362: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1449 (HY000) at line 363: The user specified as a definer ('mariadb.sys'@'localhost') does not exist
ERROR 1449 (HY000) at line 365: The user specified as a definer ('mariadb.sys'@'localhost') does not exist
ERROR 1347 (HY000) at line 370: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1347 (HY000) at line 371: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1347 (HY000) at line 376: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1347 (HY000) at line 377: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1449 (HY000) at line 382: The user specified as a definer ('mariadb.sys'@'localhost') does not exist
ERROR 1347 (HY000) at line 385: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1347 (HY000) at line 386: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1449 (HY000) at line 388: The user specified as a definer ('mariadb.sys'@'localhost') does not exist
ERROR 1347 (HY000) at line 389: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1347 (HY000) at line 390: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1449 (HY000) at line 391: The user specified as a definer ('mariadb.sys'@'localhost') does not exist
ERROR 1449 (HY000) at line 514: The user specified as a definer ('mariadb.sys'@'localhost') does not exist
ERROR 1347 (HY000) at line 515: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1347 (HY000) at line 516: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1449 (HY000) at line 517: The user specified as a definer ('mariadb.sys'@'localhost') does not exist
ERROR 1449 (HY000) at line 584: The user specified as a definer ('mariadb.sys'@'localhost') does not exist
ERROR 1347 (HY000) at line 585: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1347 (HY000) at line 586: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1449 (HY000) at line 591: The user specified as a definer ('mariadb.sys'@'localhost') does not exist
ERROR 1449 (HY000) at line 593: The user specified as a definer ('mariadb.sys'@'localhost') does not exist
ERROR 1347 (HY000) at line 594: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1347 (HY000) at line 595: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1449 (HY000) at line 596: The user specified as a definer ('mariadb.sys'@'localhost') does not exist
ERROR 1347 (HY000) at line 597: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1449 (HY000) at line 600: The user specified as a definer ('mariadb.sys'@'localhost') does not exist
ERROR 1347 (HY000) at line 601: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1347 (HY000) at line 602: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1449 (HY000) at line 605: The user specified as a definer ('mariadb.sys'@'localhost') does not exist
ERROR 1347 (HY000) at line 606: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1347 (HY000) at line 608: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1347 (HY000) at line 609: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1347 (HY000) at line 610: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1347 (HY000) at line 611: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1347 (HY000) at line 612: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1347 (HY000) at line 613: 'mysql.user' is not of type 'BASE TABLE'
ERROR 1449 (HY000) at line 636: The user specified as a definer ('mariadb.sys'@'localhost') does not exist
ERROR 1347 (HY000) at line 638: 'mysql.user' is not of type 'TABLE'
ERROR 1449 (HY000) at line 639: The user specified as a definer ('mariadb.sys'@'localhost') does not exist
ERROR 1347 (HY000) at line 663: 'mysql.user' is not of type 'BASE TABLE'
FATAL ERROR: Upgrade failed
Restore Complete!
A restart is needed to complete restore. Press enter to reboot.
- postmap: warning: /etc/postfix/dynamicmaps.cf:
- shell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
- mysql.user (a bunch here)
