Recent Update has error
dangsite
Post by dangsite »
I was curious to see how eFA would be working with option "13) Update Now".
To get right to the detail, here is the final status:
Error: Transaction test error:
  file /etc/centos-release from install of rocky-release-8.8-1.8.el8.noarch conflicts with file from package centos-stream-release-8.6-1.el8.noarch
  file /etc/redhat-release from install of rocky-release-8.8-1.8.el8.noarch conflicts with file from package centos-stream-release-8.6-1.el8.noarch
  file /etc/system-release from install of rocky-release-8.8-1.8.el8.noarch conflicts with file from package centos-stream-release-8.6-1.el8.noarch
  file /etc/system-release-cpe from install of rocky-release-8.8-1.8.el8.noarch conflicts with file from package centos-stream-release-8.6-1.el8.noarch
  file /usr/lib/os-release from install of rocky-release-8.8-1.8.el8.noarch conflicts with file from package centos-stream-release-8.6-1.el8.noarch
  file /usr/lib/systemd/system-preset/85-display-manager.preset from install of rocky-release-8.8-1.8.el8.noarch conflicts with file from package centos-stream-release-8.6-1.el8.noarch
  file /usr/lib/systemd/system-preset/90-default.preset from install of rocky-release-8.8-1.8.el8.noarch conflicts with file from package centos-stream-release-8.6-1.el8.noarch
  file /usr/lib/systemd/system-preset/99-default-disable.preset from install of rocky-release-8.8-1.8.el8.noarch conflicts with file from package centos-stream-release-8.6-1.el8.noarch
  file /usr/share/redhat-release from install of rocky-release-8.8-1.8.el8.noarch conflicts with file from package centos-stream-release-8.6-1.el8.noarch
I did ask about the future of the platform giving the changes Red Hat did with the sources and that both AlmaLinux and RockyLinux are still on a path.
I look forward to reading more.....
If you want to see all the log detail, here:
Update now, are you sure? (y/N): y
Last metadata expiration check: 2:32:29 ago on Sun 09 Jul 2023 08:26:13 AM CDT.
Dependencies resolved.
 Package                                           Architecture           Version                                                      Repository                        Size
Upgrading:
 NetworkManager                                    x86_64                 1:1.40.16-8.el8                                              stream-baseos                    2.3 M
 NetworkManager-initscripts-updown                 noarch                 1:1.40.16-8.el8                                              stream-baseos                    143 k
 NetworkManager-libnm                              x86_64                 1:1.40.16-8.el8                                              stream-baseos                    1.9 M
 apr-util                                          x86_64                 1.6.1-9.el8                                                  stream-appstream                 106 k
 apr-util-bdb                                      x86_64                 1.6.1-9.el8                                                  stream-appstream                  25 k
 apr-util-openssl                                  x86_64                 1.6.1-9.el8                                                  stream-appstream                  27 k
 binutils                                          x86_64                 2.30-121.el8                                                 stream-baseos                    5.9 M
 chkconfig                                         x86_64                 1.19.2-1.el8                                                 stream-baseos                    217 k
 cpp                                               x86_64                 8.5.0-20.el8                                                 stream-baseos                     10 M
 curl                                              x86_64                 7.61.1-30.el8_8.2                                            baseos                           352 k
 dbus                                              x86_64                 1:1.12.8-25.el8                                              stream-baseos                     38 k
 dbus-common                                       noarch                 1:1.12.8-25.el8                                              stream-baseos                     47 k
 dbus-daemon                                       x86_64                 1:1.12.8-25.el8                                              stream-baseos                    246 k
 dbus-libs                                         x86_64                 1:1.12.8-25.el8                                              stream-baseos                    185 k
 dbus-tools                                        x86_64                 1:1.12.8-25.el8                                              stream-baseos                     87 k
 dnf                                               noarch                 4.7.0-18.el8                                                 stream-baseos                    552 k
 dnf-automatic                                     noarch                 4.7.0-18.el8                                                 stream-baseos                    153 k
 dnf-data                                          noarch                 4.7.0-18.el8                                                 stream-baseos                    159 k
 dnf-plugins-core                                  noarch                 4.0.21-23.el8                                                stream-baseos                     77 k
 dracut                                            x86_64                 049-225.git20230614.el8                                      stream-baseos                    446 k
 elfutils-debuginfod-client                        x86_64                 0.189-2.el8                                                  stream-baseos                     76 k
 elfutils-default-yama-scope                       noarch                 0.189-2.el8                                                  stream-baseos                     52 k
 elfutils-libelf                                   x86_64                 0.189-2.el8                                                  stream-baseos                    232 k
 elfutils-libs                                     x86_64                 0.189-2.el8                                                  stream-baseos                    302 k
 gcc                                               x86_64                 8.5.0-20.el8                                                 stream-baseos                     24 M
 gcc-plugin-annobin                                x86_64                 8.5.0-20.el8                                                 stream-baseos                     36 k
 glibc                                             x86_64                 2.28-228.el8                                                 stream-baseos                    2.2 M
 glibc-all-langpacks                               x86_64                 2.28-228.el8                                                 stream-baseos                     26 M
 glibc-common                                      x86_64                 2.28-228.el8                                                 stream-baseos                    1.0 M
 glibc-devel                                       x86_64                 2.28-228.el8                                                 stream-baseos                     85 k
 glibc-gconv-extra                                 x86_64                 2.28-228.el8                                                 stream-baseos                    1.7 M
 glibc-headers                                     x86_64                 2.28-228.el8                                                 stream-baseos                    581 k
 gnutls                                            x86_64                 3.6.16-7.el8                                                 stream-baseos                    1.0 M
 grub2-common                                      noarch                 1:2.02-148.el8.rocky.0.3                                     baseos                           894 k
 grub2-tools                                       x86_64                 1:2.02-148.el8.rocky.0.3                                     baseos                           2.0 M
 grub2-tools-efi                                   x86_64                 1:2.02-148.el8.rocky.0.3                                     baseos                           478 k
 grub2-tools-extra                                 x86_64                 1:2.02-148.el8.rocky.0.3                                     baseos                           1.1 M
 grub2-tools-minimal                               x86_64                 1:2.02-148.el8.rocky.0.3                                     baseos                           212 k
 grubby                                            x86_64                 8.40-48.el8                                                  stream-baseos                     50 k
 httpd                                             x86_64                 2.4.37-56.module+el8.8.0+1284+07ef499e.6                     appstream                        1.4 M
 httpd-filesystem                                  noarch                 2.4.37-56.module+el8.8.0+1284+07ef499e.6                     appstream                         42 k
 httpd-tools                                       x86_64                 2.4.37-56.module+el8.8.0+1284+07ef499e.6                     appstream                        109 k
 hwdata                                            noarch                 0.314-8.18.el8                                               stream-baseos                    1.8 M
 iproute                                           x86_64                 6.2.0-2.el8                                                  stream-baseos                    880 k
 kbd                                               x86_64                 2.0.4-11.el8                                                 stream-baseos                    422 k
 kbd-legacy                                        noarch                 2.0.4-11.el8                                                 stream-baseos                    536 k
 kbd-misc                                          noarch                 2.0.4-11.el8                                                 stream-baseos                    1.6 M
 kernel-headers                                    x86_64                 4.18.0-500.el8                                               stream-baseos                     11 M
 krb5-devel                                        x86_64                 1.18.2-25.el8_8                                              baseos                           561 k
 krb5-libs                                         x86_64                 1.18.2-25.el8_8                                              baseos                           841 k
 libblkid                                          x86_64                 2.32.1-42.el8_8                                              baseos                           219 k
 libcurl                                           x86_64                 7.61.1-30.el8_8.2                                            baseos                           302 k
 libdnf                                            x86_64                 0.63.0-16.el8                                                stream-baseos                    720 k
 libfastjson                                       x86_64                 0.99.9-2.el8                                                 stream-appstream                  38 k
 libfdisk                                          x86_64                 2.32.1-42.el8_8                                              baseos                           252 k
 libgcc                                            x86_64                 8.5.0-20.el8                                                 stream-baseos                     81 k
 libgomp                                           x86_64                 8.5.0-20.el8                                                 stream-baseos                    208 k
 libibverbs                                        x86_64                 46.0-1.el8.1                                                 stream-baseos                    410 k
 libkadm5                                          x86_64                 1.18.2-25.el8_8                                              baseos                           187 k
 libmd                                             x86_64                 1.1.0-1.el8                                                  epel                              45 k
 libmount                                          x86_64                 2.32.1-42.el8_8                                              baseos                           235 k
 libnftnl                                          x86_64                 1.2.2-3.el8                                                  stream-baseos                     87 k
 libsmartcols                                      x86_64                 2.32.1-42.el8_8                                              baseos                           178 k
 libsolv                                           x86_64                 0.7.20-6.el8                                                 stream-baseos                    376 k
 libssh                                            x86_64                 0.9.6-10.el8_8                                               baseos                           217 k
 libssh-config                                     noarch                 0.9.6-10.el8_8                                               baseos                            19 k
 libstdc++                                         x86_64                 8.5.0-20.el8                                                 stream-baseos                    458 k
 libtalloc                                         x86_64                 2.4.0-3.el8                                                  stream-baseos                     50 k
 libtiff                                           x86_64                 4.0.9-28.el8_8                                               appstream                        188 k
 libuuid                                           x86_64                 2.32.1-42.el8_8                                              baseos                            97 k
 libwebp                                           x86_64                 1.0.0-9.el8                                                  stream-appstream                 274 k
 memstrack                                         x86_64                 0.2.5-2.el8                                                  stream-baseos                     52 k
 mod_http2                                         x86_64                 1.15.7-8.module+el8.8.0+1284+07ef499e.3                      appstream                        154 k
 mod_ssl                                           x86_64                 1:2.4.37-56.module+el8.8.0+1284+07ef499e.6                   appstream                        139 k
 mysql-common                                      x86_64                 8.0.32-1.module+el8.8.0+1283+4b88a3a8.0.1                    appstream                        137 k
 mysql-libs                                        x86_64                 8.0.32-1.module+el8.8.0+1283+4b88a3a8.0.1                    appstream                        1.5 M
 pam                                               x86_64                 1.3.1-27.el8                                                 stream-baseos                    850 k
 perl-DBI                                          x86_64                 1.641-4.module_el8+332+132e4365                              stream-appstream                 765 k
 perl-IO-Socket-SSL                                noarch                 2.066-4.module_el8+339+1ec643e0                              stream-appstream                 304 k
 perl-Net-SSLeay                                   x86_64                 1.88-2.module_el8+339+1ec643e0                               stream-appstream                 402 k
 platform-python                                   x86_64                 3.6.8-52.el8                                                 stream-baseos                     86 k
 protobuf-c                                        x86_64                 1.3.0-8.el8                                                  stream-appstream                  37 k
 python3-cffi                                      x86_64                 1.11.5-6.el8                                                 stream-baseos                    249 k
 python3-cryptography                              x86_64                 3.2.1-6.el8                                                  stream-baseos                    641 k
 python3-dnf                                       noarch                 4.7.0-18.el8                                                 stream-baseos                    604 k
 python3-dnf-plugins-core                          noarch                 4.0.21-23.el8                                                stream-baseos                    279 k
 python3-hawkey                                    x86_64                 0.63.0-16.el8                                                stream-baseos                    118 k
 python3-libdnf                                    x86_64                 0.63.0-16.el8                                                stream-baseos                    787 k
 python3-libs                                      x86_64                 3.6.8-52.el8                                                 stream-baseos                    8.4 M
 python3-requests                                  noarch                 2.20.0-4.el8                                                 stream-baseos                    135 k
 rdma-core                                         x86_64                 46.0-1.el8.1                                                 stream-baseos                     68 k
 rocky-gpg-keys                                    noarch                 8.8-1.8.el8                                                  baseos                            13 k
 rocky-release                                     noarch                 8.8-1.8.el8                                                  baseos                            22 k
 rocky-repos                                       noarch                 8.8-1.8.el8                                                  baseos                            15 k
 rsyslog                                           x86_64                 8.2102.0-15.el8                                              stream-appstream                 778 k
 shadow-utils                                      x86_64                 2:4.6-18.el8                                                 stream-baseos                    1.3 M
 sqlite-libs                                       x86_64                 3.26.0-18.el8_8                                              baseos                           580 k
 systemd                                           x86_64                 239-76.el8                                                   stream-baseos                    3.8 M
 systemd-libs                                      x86_64                 239-76.el8                                                   stream-baseos                    1.1 M
 systemd-pam                                       x86_64                 239-76.el8                                                   stream-baseos                    505 k
 systemd-udev                                      x86_64                 239-76.el8                                                   stream-baseos                    1.6 M
 systemtap-sdt-devel                               x86_64                 4.9-1.el8                                                    stream-appstream                  88 k
 util-linux                                        x86_64                 2.32.1-42.el8_8                                              baseos                           2.5 M
 yum                                               noarch                 4.7.0-18.el8                                                 stream-baseos                    208 k
 zlib                                              x86_64                 1.2.11-25.el8                                                stream-baseos                    103 k
 zlib-devel                                        x86_64                 1.2.11-25.el8                                                stream-baseos                     59 k
Transaction Summary
Upgrade  106 Packages
Total download size: 136 M
Downloading Packages:
(1/106): apr-util-openssl-1.6.1-9.el8.x86_64.rpm        134 kB/s |  27 kB     00:00
(2/106): apr-util-bdb-1.6.1-9.el8.x86_64.rpm        121 kB/s |  25 kB     00:00
(3/106): apr-util-1.6.1-9.el8.x86_64.rpm        437 kB/s | 106 kB     00:00
(4/106): libfastjson-0.99.9-2.el8.x86_64.rpm        386 kB/s |  38 kB     00:00
(5/106): libwebp-1.0.0-9.el8.x86_64.rpm        1.3 MB/s | 274 kB     00:00
(6/106): perl-DBI-1.641-4.module_el8+332+132e4365.x86_64.rpm        4.1 MB/s | 765 kB     00:00
(7/106): perl-IO-Socket-SSL-2.066-4.module_el8+339+1ec643e0.noarch.rpm        1.7 MB/s | 304 kB     00:00
(8/106): protobuf-c-1.3.0-8.el8.x86_64.rpm        720 kB/s |  37 kB     00:00
(9/106): perl-Net-SSLeay-1.88-2.module_el8+339+1ec643e0.x86_64.rpm        3.8 MB/s | 402 kB     00:00
(10/106): systemtap-sdt-devel-4.9-1.el8.x86_64.rpm        1.1 MB/s |  88 kB     00:00
(11/106): rsyslog-8.2102.0-15.el8.x86_64.rpm        4.8 MB/s | 778 kB     00:00
(12/106): NetworkManager-initscripts-updown-1.40.16-8.el8.noarch.rpm        1.7 MB/s | 143 kB     00:00
(13/106): NetworkManager-1.40.16-8.el8.x86_64.rpm        3.6 MB/s | 2.3 MB     00:00
(14/106): chkconfig-1.19.2-1.el8.x86_64.rpm        2.5 MB/s | 217 kB     00:00
(15/106): NetworkManager-libnm-1.40.16-8.el8.x86_64.rpm        2.4 MB/s | 1.9 MB     00:00
(16/106): dbus-1.12.8-25.el8.x86_64.rpm        532 kB/s |  38 kB     00:00
(17/106): dbus-common-1.12.8-25.el8.noarch.rpm        538 kB/s |  47 kB     00:00
(18/106): dbus-daemon-1.12.8-25.el8.x86_64.rpm        1.8 MB/s | 246 kB     00:00
(19/106): dbus-libs-1.12.8-25.el8.x86_64.rpm        1.7 MB/s | 185 kB     00:00
(20/106): binutils-2.30-121.el8.x86_64.rpm        4.3 MB/s | 5.9 MB     00:01
(21/106): dbus-tools-1.12.8-25.el8.x86_64.rpm        506 kB/s |  87 kB     00:00
(22/106): dnf-automatic-4.7.0-18.el8.noarch.rpm        1.4 MB/s | 153 kB     00:00
(23/106): dnf-4.7.0-18.el8.noarch.rpm        3.5 MB/s | 552 kB     00:00
(24/106): dnf-plugins-core-4.0.21-23.el8.noarch.rpm        596 kB/s |  77 kB     00:00
(25/106): dnf-data-4.7.0-18.el8.noarch.rpm        838 kB/s | 159 kB     00:00
(26/106): elfutils-debuginfod-client-0.189-2.el8.x86_64.rpm        1.2 MB/s |  76 kB     00:00
(27/106): dracut-049-225.git20230614.el8.x86_64.rpm        3.4 MB/s | 446 kB     00:00
(28/106): elfutils-default-yama-scope-0.189-2.el8.noarch.rpm        626 kB/s |  52 kB     00:00
(29/106): elfutils-libelf-0.189-2.el8.x86_64.rpm        2.5 MB/s | 232 kB     00:00
(30/106): elfutils-libs-0.189-2.el8.x86_64.rpm        1.5 MB/s | 302 kB     00:00
(31/106): gcc-plugin-annobin-8.5.0-20.el8.x86_64.rpm        438 kB/s |  36 kB     00:00
(32/106): cpp-8.5.0-20.el8.x86_64.rpm        4.4 MB/s |  10 MB     00:02
(33/106): glibc-2.28-228.el8.x86_64.rpm        1.9 MB/s | 2.2 MB     00:01
(34/106): glibc-common-2.28-228.el8.x86_64.rpm        1.6 MB/s | 1.0 MB     00:00
(35/106): glibc-devel-2.28-228.el8.x86_64.rpm        1.0 MB/s |  85 kB     00:00
(36/106): glibc-gconv-extra-2.28-228.el8.x86_64.rpm        1.8 MB/s | 1.7 MB     00:00
(37/106): glibc-headers-2.28-228.el8.x86_64.rpm        2.2 MB/s | 581 kB     00:00
(38/106): gnutls-3.6.16-7.el8.x86_64.rpm        2.4 MB/s | 1.0 MB     00:00
(39/106): grubby-8.40-48.el8.x86_64.rpm        726 kB/s |  50 kB     00:00
(40/106): hwdata-0.314-8.18.el8.noarch.rpm        2.7 MB/s | 1.8 MB     00:00
(41/106): iproute-6.2.0-2.el8.x86_64.rpm        2.5 MB/s | 880 kB     00:00
(42/106): kbd-2.0.4-11.el8.x86_64.rpm        1.4 MB/s | 422 kB     00:00
(43/106): kbd-legacy-2.0.4-11.el8.noarch.rpm        2.3 MB/s | 536 kB     00:00
(44/106): kbd-misc-2.0.4-11.el8.noarch.rpm        2.9 MB/s | 1.6 MB     00:00
(45/106): gcc-8.5.0-20.el8.x86_64.rpm        3.5 MB/s |  24 MB     00:06
(46/106): libdnf-0.63.0-16.el8.x86_64.rpm        2.5 MB/s | 720 kB     00:00
(47/106): libgcc-8.5.0-20.el8.x86_64.rpm        568 kB/s |  81 kB     00:00
(48/106): libgomp-8.5.0-20.el8.x86_64.rpm        1.6 MB/s | 208 kB     00:00
(49/106): libibverbs-46.0-1.el8.1.x86_64.rpm        2.7 MB/s | 410 kB     00:00
(50/106): libnftnl-1.2.2-3.el8.x86_64.rpm        1.4 MB/s |  87 kB     00:00
(51/106): libsolv-0.7.20-6.el8.x86_64.rpm        3.0 MB/s | 376 kB     00:00
(52/106): libstdc++-8.5.0-20.el8.x86_64.rpm        1.7 MB/s | 458 kB     00:00
(53/106): libtalloc-2.4.0-3.el8.x86_64.rpm        813 kB/s |  50 kB     00:00
(54/106): memstrack-0.2.5-2.el8.x86_64.rpm        665 kB/s |  52 kB     00:00
(55/106): pam-1.3.1-27.el8.x86_64.rpm        2.4 MB/s | 850 kB     00:00
(56/106): platform-python-3.6.8-52.el8.x86_64.rpm        2.1 MB/s |  86 kB     00:00
(57/106): python3-cffi-1.11.5-6.el8.x86_64.rpm        2.2 MB/s | 249 kB     00:00
(58/106): python3-cryptography-3.2.1-6.el8.x86_64.rpm        3.0 MB/s | 641 kB     00:00
(59/106): python3-dnf-4.7.0-18.el8.noarch.rpm        3.0 MB/s | 604 kB     00:00
(60/106): python3-dnf-plugins-core-4.0.21-23.el8.noarch.rpm        2.4 MB/s | 279 kB     00:00
(61/106): python3-hawkey-0.63.0-16.el8.x86_64.rpm        1.7 MB/s | 118 kB     00:00
(62/106): python3-libdnf-0.63.0-16.el8.x86_64.rpm        2.7 MB/s | 787 kB     00:00
(63/106): kernel-headers-4.18.0-500.el8.x86_64.rpm        3.1 MB/s |  11 MB     00:03
(64/106): glibc-all-langpacks-2.28-228.el8.x86_64.rpm        2.9 MB/s |  26 MB     00:08
(65/106): python3-requests-2.20.0-4.el8.noarch.rpm        398 kB/s | 135 kB     00:00
(66/106): rdma-core-46.0-1.el8.1.x86_64.rpm        974 kB/s |  68 kB     00:00
(67/106): shadow-utils-4.6-18.el8.x86_64.rpm        2.6 MB/s | 1.3 MB     00:00
(68/106): systemd-libs-239-76.el8.x86_64.rpm        2.6 MB/s | 1.1 MB     00:00
(69/106): systemd-pam-239-76.el8.x86_64.rpm        2.7 MB/s | 505 kB     00:00
(70/106): systemd-239-76.el8.x86_64.rpm        2.8 MB/s | 3.8 MB     00:01
(71/106): yum-4.7.0-18.el8.noarch.rpm        1.5 MB/s | 208 kB     00:00
(72/106): zlib-1.2.11-25.el8.x86_64.rpm        1.4 MB/s | 103 kB     00:00
(73/106): systemd-udev-239-76.el8.x86_64.rpm        2.8 MB/s | 1.6 MB     00:00
(74/106): zlib-devel-1.2.11-25.el8.x86_64.rpm        705 kB/s |  59 kB     00:00
(75/106): httpd-filesystem-2.4.37-56.module+el8.8.0+1284+07ef499e.6.noarch.rpm        118 kB/s |  42 kB     00:00
(76/106): httpd-tools-2.4.37-56.module+el8.8.0+1284+07ef499e.6.x86_64.rpm        725 kB/s | 109 kB     00:00
(77/106): httpd-2.4.37-56.module+el8.8.0+1284+07ef499e.6.x86_64.rpm        1.8 MB/s | 1.4 MB     00:00
(78/106): libtiff-4.0.9-28.el8_8.x86_64.rpm        707 kB/s | 188 kB     00:00
(79/106): mod_http2-1.15.7-8.module+el8.8.0+1284+07ef499e.3.x86_64.rpm        1.2 MB/s | 154 kB     00:00
(80/106): mod_ssl-2.4.37-56.module+el8.8.0+1284+07ef499e.6.x86_64.rpm        934 kB/s | 139 kB     00:00
(81/106): mysql-common-8.0.32-1.module+el8.8.0+1283+4b88a3a8.0.1.x86_64.rpm        1.6 MB/s | 137 kB     00:00
(82/106): python3-libs-3.6.8-52.el8.x86_64.rpm        2.5 MB/s | 8.4 MB     00:03
(83/106): mysql-libs-8.0.32-1.module+el8.8.0+1283+4b88a3a8.0.1.x86_64.rpm        5.3 MB/s | 1.5 MB     00:00
(84/106): curl-7.61.1-30.el8_8.2.x86_64.rpm        660 kB/s | 352 kB     00:00
(85/106): grub2-common-2.02-148.el8.rocky.0.3.noarch.rpm        2.1 MB/s | 894 kB     00:00
(86/106): grub2-tools-efi-2.02-148.el8.rocky.0.3.x86_64.rpm        3.8 MB/s | 478 kB     00:00
(87/106): grub2-tools-2.02-148.el8.rocky.0.3.x86_64.rpm        3.9 MB/s | 2.0 MB     00:00
(88/106): grub2-tools-minimal-2.02-148.el8.rocky.0.3.x86_64.rpm        2.4 MB/s | 212 kB     00:00
(89/106): krb5-devel-1.18.2-25.el8_8.x86_64.rpm        3.3 MB/s | 561 kB     00:00
(90/106): grub2-tools-extra-2.02-148.el8.rocky.0.3.x86_64.rpm        3.3 MB/s | 1.1 MB     00:00
(91/106): libblkid-2.32.1-42.el8_8.x86_64.rpm        4.4 MB/s | 219 kB     00:00
(92/106): krb5-libs-1.18.2-25.el8_8.x86_64.rpm        3.5 MB/s | 841 kB     00:00
(93/106): libfdisk-2.32.1-42.el8_8.x86_64.rpm        5.6 MB/s | 252 kB     00:00
(94/106): libcurl-7.61.1-30.el8_8.2.x86_64.rpm        3.8 MB/s | 302 kB     00:00
(95/106): libkadm5-1.18.2-25.el8_8.x86_64.rpm        4.2 MB/s | 187 kB     00:00
(96/106): libmount-2.32.1-42.el8_8.x86_64.rpm        5.4 MB/s | 235 kB     00:00
(97/106): libsmartcols-2.32.1-42.el8_8.x86_64.rpm        3.9 MB/s | 178 kB     00:00
(98/106): libssh-0.9.6-10.el8_8.x86_64.rpm        4.9 MB/s | 217 kB     00:00
(99/106): libssh-config-0.9.6-10.el8_8.noarch.rpm        482 kB/s |  19 kB     00:00
(100/106): libuuid-2.32.1-42.el8_8.x86_64.rpm        2.2 MB/s |  97 kB     00:00
(101/106): rocky-gpg-keys-8.8-1.8.el8.noarch.rpm        240 kB/s |  13 kB     00:00
(102/106): rocky-release-8.8-1.8.el8.noarch.rpm        539 kB/s |  22 kB     00:00
(103/106): rocky-repos-8.8-1.8.el8.noarch.rpm        398 kB/s |  15 kB     00:00
(104/106): sqlite-libs-3.26.0-18.el8_8.x86_64.rpm        8.4 MB/s | 580 kB     00:00
(105/106): util-linux-2.32.1-42.el8_8.x86_64.rpm        15 MB/s | 2.5 MB     00:00
(106/106): libmd-1.1.0-1.el8.x86_64.rpm        223 kB/s |  45 kB     00:00
Total        7.9 MB/s | 136 MB     00:17
Running transaction check
Transaction check succeeded.
Running transaction test
The downloaded packages were saved in cache until the next successful transaction.
You can remove cached packages by executing 'yum clean packages'.
yum clean packages does not have anything to act on. The update stopped due to the error.
