opendkim problem
efagokan1
opendkim problem
Post by efagokan1 »
Hello
I am getting an error as below. What could be the cause of the problem?
OpenDKIM Filter: accept() returned invalid socket (Numerical result out of range), try again
Re: opendkim problem
Did you try a google search for this error?
This is the first result I found:
https://bugzilla.redhat.com/show_bug.cgi?id=2070441
Is your system under load? Are you receiving a lot of requests and your system is running out of resources? (system handles, etc)
efagokan1
Post by efagokan1 »
Yes, I'm checking.
thanks.
