SORBS
Posted: 24 Mar 2023 07:22
by efagokan1
Hello
Gmail ip addresses enter SORBS lists. That's why emails go to spam.
How can I remove only one domain from SORBS control?
Re: SORBS
Posted: 25 Mar 2023 03:58
by Aryfir
Since i dont know how many SORBS score you have and i assume that your matching rule of SORBS is RCVD_IN_SORBS;
Put this on your local.cf
header GMAIL_TLD From =~ /(gmail.com)/i
describe GMAIL_TLD Gmail Trusted
score GMAIL_TLD 0.0
meta CUSTOM_GMAIL_WHLST (GMAIL_TLD + RCVD_IN_SORBS)
describe CUSTOM_GMAIL_WHLST Message received in 2 rules
score CUSTOM_GMAIL_WHLST -1.0
Logic is simple, whenever email coming from gmail.com it will give zero score (GMAIL_TLD) and meta will combine ruleset from GMAIL_TLD & RCVD_IN_SORBS to give minus 1 score (you may edit this score to fit on your needs)
Please run spamassassin --lint cli to check if that config is correct and follow with systemctl restart spamassassin
Re: SORBS
Posted: 28 Mar 2023 07:11
by efagokan1
Hello
Customers are using Google Workspace. So they use their own domain names. I can't add everyone individually.
How else can we find a solution?
Re: SORBS
Posted: 24 Apr 2023 04:07
Can you show me the spamassassin rule hit you are getting that causes the emails to be flagged as spam?
In my installation, I have two rules containing the string SORBS and they are
1/ RCVD_IN_SORBS_DUL
2/ RCVD_IN_SORBS_WEB
