unable to install
unable to install
I am having issues install efa, i have downloaded the iso to centos 7 (latest) version
I did the minimum install; setup a fixed ip address and rebooted.
Did the command "curl -sSL https://install.efa-project.org | bash" goes through with the install but errors out
"installing eFa packages (this can take a while)
ERROR: eFa4 failed to install
********* Script aborted *****
i have redone the CentOS install and i get the same error over and over i even tried the other way of installing
wget -O build.bash https://install.efa-project.org
sudo bash build.bash
and i get the same error.
I dont know Linus at all (windows man); and i dont have a clue to what to do to get this to work again
Any ideas?
Andrew
Any ideas?
Andrew
Re: unable to install
Hi Tasone,
There's an dependency error, that affects updates and I think applies to new installs too..
Take a look here. Guess ADDING the additional ius Archive repo , as mentioned there, could solve things.
viewtopic.php?t=5155
Error: Package: 1:eFa-4.0.4-39.eFa.el7.noarch (eFa4)
Requires: php74-gmp >= 7.4.28-1viewtopic.php?t=5155
Hello
Thanks,
I went through that post and it is the same error i get.
The only thing from that post is when you do the yum list installed |grep php74 command it says it shows
mod_php74.x86_64 7.4.33-1.el7.ius @sans-ius
php74-cli.x86_64 7.4.33-1.el7.ius @sans-ius
php74-common.x86_64 7.4.33-1.el7.ius @sans-ius
php74-fpm.x86_64 7.4.33-1.el7.ius @sans-ius
php74-gd.x86_64 7.4.33-1.el7.ius @sans-ius
php74-gmp.x86_64 7.4.33-1.el7.ius @sans-ius
php74-json.x86_64 7.4.33-1.el7.ius @sans-ius
php74-ldap.x86_64 7.4.33-1.el7.ius @sans-ius
php74-mbstring.x86_64 7.4.33-1.el7.ius @sans-ius
php74-mysqlnd.x86_64 7.4.33-1.el7.ius @sans-ius
php74-pdo.x86_64 7.4.33-1.el7.ius @sans-ius
php74-process.x86_64 7.4.33-1.el7.ius @sans-ius
php74-xml.x86_64 7.4.33-1.el7.ius @sans-ius
i only get
and when i try and install eFa i get the same error
Andrew
Thanks,
i only get
Andrew
You just prooved my point, ADDING the additional ius Archive repo is required for new installs too.
Before you exec the build script, the repo should be present, as all required php moved there:
https://repo.ius.io/archive/7/x86_64/packages/p/
It would be great if the eFa moderators would step in to solve this one as adding repos requires manual intervention of the install process.
I think i added that repo (from the post you linked to; i left it in to check)
But i am getting the same error.
I got to learn Linus as i only know the basic commands and the VI editor and that is about it
Can i check that following that post to add that archive repo and just leaving it there is what you asked me to do?
Andrew
Andrew
to check the current repos'
If the Archive repo didnt show up
Paste this into the file
result should contain these lines
ius IUS Community Packages for Enterprise Linux 7
ius-archive/x86_64 IUS Community Archive Packages for Enterprise Linux 7 11,084
If present, run the install again
Hint,
have a look at mc.
start mc and and disable the Use internal edit (under the Options)
In case of errors during install/update, check the logiles
can be found here
yum repolistCode: Select all
vi /etc/yum.repos.d/ius-archive.repoCode: Select all
[ius-archive]
name=IUS Community Archive Packages for Enterprise Linux 7
baseurl=https://repo.ius.io/archive/7/$basearch/
enabled=1
gpgcheck=0
yum repolistius IUS Community Packages for Enterprise Linux 7
Hint,
have a look at mc.
yum install mcIn case of errors during install/update, check the logiles
can be found here
/var/log/eFa“We are stuck with technology when what we really want is just stuff that works.” -Douglas Adams
That worked
That should be added to the install page for eFa
Thank you so much for your time and help with this issue.
Andrew
That worked
Andrew
I will work on getting things fixedup for CentOS 7 here. Apologies for the delay. I have had health issues.
HI,
No worry's i also had some health issues (had a op on my spine and spinel cord)
just trying to keep my mind doing stuff as i not aloud to pick anything over the weight of a small coke bottle.
Andrew
Andrew
