fly by error message...
ManFarang
Post by ManFarang »
whenever I logon there's an error message flying by that I can't catch in the terminal. It disappears out of the top of the screen.
After fiddling around with VirtualBox recording and VLC image conversions I found the attached message...
Any idea if it is important? Or just ignore?
Else what to do?
Thx for your help.
rgds, man
dangsite
Re: fly by error message...
Post by dangsite »
what user are you logging into the instance?
Do you have the file /etc/clamav-unofficial-sigs/user.conf on your system? There is an attempt to do a "grep" on the file within an if statement.
If there is an error, I would suspect the file does not exist or is not available to the end user (your login use).
That is what I can suggest from my 10 minute review from my eFa 4.x system.
ManFarang
Post by ManFarang »
- I'm logging on with the admin account
- the file is available (as you can see in the error message. A line of code is displayed and flagged erroneous)
- I'm not a BASH Guru but I think there's something wrong with the syntax
HTH
rgds, man
