IPv6 outgoing relay
Posted: 25 Oct 2022 11:06
When I try to add an ipv6 subnet in the outbound mail relay and save then opendkim crashes on restart.
This is what I found in /var/log/messages:
Multiple ipv4 subnets are no problem.
It's only when adding an ipv6 subnet that openskim crashes.
Am I doing something wrong? Is it syntax?
Any clue to the solution is appreciated.
opendkim: /etc/opendkim.conf: 1.1.1.1/24 aaaa:bbbb:cccc:dddd::/64: dkimf_db_open(): Unknown database typeIt's only when adding an ipv6 subnet that openskim crashes.
