E.F.A. 3.0.0.3 update released
Important news
Locked
darky83
Site Admin
Post by darky83 »
The following issues have been fixed in 3.0.0.3:
  • Issue #62 Bug- Add perl-Compress-Raw-Zlib to fix failed build in previous versions
  • Issue #60 Bug - kam.cf.backup parsed by spamassassin
  • Issue #61 Bug - Domain Administrator cannot delete domain only whitelist/blacklist
  • Issue #30 Enhancement - Filter non-spam from quarantine reports
  • Issue #56 Enhancement - Add yum update exclusions
  • Issue #55 Bug - Kernel Update from yum update breaks vmware-tools (open-vm-tools)
  • Issue #48 and #47 Bug - MailWatch update to include lists.php typo and Release All bugs
  • Issue #53 Bug - Fix postfix queue directories after yum update
  • Issue #17 Enhancement - Trusted Networks Support for learn-msg.cgi
  • Issue #16 Enhancement - Automated Backup of MySQL and Settings
  • Issue #12 Enhancement - Improved handling of transport file with EFA-Configure
We encourage everyone to update.
If you have auto update enabled your system will automatically update to this new release.
If you have auto update disabled you will need to run the update command manually:
1) login to your box with ssh
2) press ’1′ to get an shell
3) type:
You can download the latest VM image version from http://efa-project.org/download
Locked
