installing vmware tools gives permission denied
doggy101
Post by doggy101 »
when installing the vm tools the following error occeurs
[root@EFAmailscanner vmware-tools-distrib]# ./vmware-install.pl --default
-bash: ./vmware-install.pl: Permission denied
user root has full permission on the folder
anyone?
Re: installing vmware tools gives permission denied
Do you have execute permissions on the perl script itself?
doggy101
Post by doggy101 »
yes permissions are set at 0777 and recursive set through the whle folder.
Even though you are root, what happens when you sudo?
sudo  ./vmware-install.pl --default
doggy101
Post by doggy101 »
still permission denied :-(
Wow. What does the permissions on perl look like?
/usr/bin/perl I think.
doggy101
Post by doggy101 »
root has 0777
strange huh
darky83
Site Admin
Post by darky83 »
Are you sure the installer for vmware tools is valid?
Sound more like your vmware tools source is corrupt.
doggy101
Post by doggy101 »
used it on several VM's with no issues just this one VM (ESX5.1)
Sorry I am at a loss here. Something is wrong with your root access...I think that is also causing you issues with razor.
dku
Post by dku »
had the same problem. i could install vmware tools using
perl vmware-install.pl
lexxerd
Post by lexxerd »
dku wrote:had the same problem. i could install vmware tools using
I made an account on this site just to reply that this was very helpful and worked for me!
mary
Post by mary »
It has worked for me too, so many thanks even from my side :D
