document.xml.rels blocked!
max_of_tl
Post by max_of_tl »
There's something you should fix.
docx files are zip and contain files ending in .xml.rels
Unfortunately, the default filename ruleset allows files ending in .xml.rel
(no s).
/etc/MailScanner/filename.rules.conf:
# These are in the archives which are Microsoft Office 2007 files (e.g. docx)
allow \.xml\d*\.rel$ - -
allow \.x\d+\.rel$ - -
allow \.rtf$ - -
It should probably be
allow \.xml\.rels?$ - -
Figure 1:
eFa - problem; blocking docx - as zip containing files.png (54.92 KiB) Viewed 14854 times
Edit: - more details...
I also found that a similar thing happens with the pptx format, but for somefile.vml.rels. So, the match may need to be something like
allow \.[vx]ml\.rels?$ - -
... or, whatever else can be in this internal format.
