Date Rollback Condition is BAD
Posted: 02 Mar 2014 04:23
My NTP server was rebuilt today, and for a brief time was handing out a time in the past.
EFA saw it and synced to the past.
It appears to be walking through all emails in the quarantine????
Processed: 2,082,528 90.8Gb
Clean: 2,081,286 99.9%
Viruses: 0 0.0%
Top Virus: None
Blocked files: 1,242 0.1%
Others: 0 0.0%
Spam: 0 0.0%
High Scoring Spam: 0 0.0%
MCP: 0 0.0%
High Scoring MCP: 0 0.0%
Oh no!!!!!
Re: Date Rollback Condition is BAD
Posted: 02 Mar 2014 04:36
Okay, it looks like the system is stabilizing now that the time is correct...
CPU utilization is still high due to incoming queue being backlogged...
Monitoring to see what happens...
Posted: 02 Mar 2014 05:16
Something wrong...this appears to have started prior to the NTP server rebuild.
MailWatch shows the system looping through previously quarantined messages and marking them as clean repeatedly...
System is rapidly declining on disk space.
Watching incoming queue...it is trending downward slowly.
Posted: 02 Mar 2014 05:36
Ok, found clamd dead. Was retrying scanning on a batch of messages over and over.
Started clamd...
MailScanner processes are turning zombie...
Posted: 02 Mar 2014 05:41
Moved /var/spool/postfix/hold --> /var/spool/postfix/hold.chk
Created new hold
System now normal...something corrupt in hold queue? Checking...
Posted: 02 Mar 2014 07:05
Nothing corrupt in hold queue...all messages eventually processed.
However, clamd went down again part way....as soon as it did, the looping started again.
I had to stop MailScanner, start clamd, and start MailScanner.
Will be monitoring this very closely.
Posted: 02 Mar 2014 07:19
by ramtech
Sounds less than fun.
Looking forward reading to the progress.
Posted: 02 Mar 2014 08:26
It appears that a combination of CPU overload and too many MailScanner threads may be at fault...I think that clamd is getting pushed to its limit with the large number of incoming messages.
I have reduced my MailScanner threads to 5. Will test with a large queue again and see what happens.
Posted: 03 Mar 2014 11:18
Yep, too many MailScanner children was the culprit.
Posted: 26 Mar 2014 20:26
