MailScanner mailto: false positives
max_of_tl
Post by max_of_tl »
I am getting false positives with bad URL for mailto: address links. An example:
MailScanner has detected a possible fraud attempt from "domain.com" claiming to be mailto:user@domain.com
The following was added to /etc/MailScanner/phishing.safe.sites.conf:
mailto:*
*.domain.com
This did not fix the false messages.
Does anyone know what might cause this?
Thanks guys ,
Max
max_of_tl
Re: MailScanner mailto: false positives
Post by max_of_tl »
In the meantime,
In
I changed:
Highlight Mailto Phishing = no
I did not notice this until just recently (after hacking around in Message.pm). This may be my solution.
max_of_tl wrote: 13 Jul 2022 15:20 Hi,
mailto:*
*.domain.com
Thanks guys ,
Max
According to phishing.safe.sites.conf
# Add your custom Phishing safe sites to the
# phishing.safe.sites.custom file in your MailScanner
# directory. Note that phishing.safe.sites.conf is
# overwritten when ms-update-phishing is executed.
So I've added my entries into phishing.safe.sites.custom:
*.domain.com
and then I have run the ms-update-phishing command
It works perfectly for me.
I do have to keep an eye on the messages coming in so I can update valid domain links send on behalf of another party.
