MailScanner and MariaDB were automatically updated today with the result:
/etc/cron.daily/0yum-daily.cron:
warning: /etc/my.cnf.d/mariadb-server.cnf created as /etc/my.cnf.d/mariadb-server.cnf.rpmnew
warning: /etc/MailScanner/MailScanner.conf created as /etc/MailScanner/MailScanner.conf.rpmnew
Added new: Lockfile Dir = /var/spool/MailScanner/incoming/Locks
Added new: include /etc/MailScanner/conf.d/*
Summary
Read 390 settings from old /etc/MailScanner/MailScanner.conf.original
Used 389 settings from old /etc/MailScanner/MailScanner.conf.original
Used 3 default settings from new /etc/MailScanner/MailScanner.conf.dist
Preparing to update eFa...
checkmodule: loading policy configuration from /var/eFa/lib/selinux/eFa.te
checkmodule: policy configuration loaded
checkmodule: writing binary representation (version 19) to /var/eFa/lib/selinux/eFa.mod ERROR 1292 (22007) at line 46: Incorrect datetime value: '1970-01-01 00:00:01' for column ``.``.`lastsent` at row 1 Update completed successfully!
The following updates will be applied on av01.vyvo.cz:
Package Arch Version Repository
Size ================================================================================
Installing:
eFa noarch 1:4.0.4-38.eFa.el7 eFa4 125 k
replacing mariadb102.x86_64 3:10.2.30-1.el7.ius
replacing mariadb102-common.x86_64 3:10.2.30-1.el7.ius
replacing mariadb102-errmsg.x86_64 3:10.2.30-1.el7.ius
replacing mariadb102-libs.x86_64 3:10.2.30-1.el7.ius
replacing mariadb102-server.x86_64 3:10.2.30-1.el7.ius
Updating:
MailScanner noarch 5.4.5-1.eFa.el7 eFa4 601 k
unrar x86_64 6.1.7-1.eFa.el7 eFa4 132 k
Installing for dependencies:
mariadb104 x86_64 3:10.4.17-1.el7.ius ius 6.2 M
mariadb104-common x86_64 3:10.4.17-1.el7.ius ius 68 k
mariadb104-errmsg x86_64 3:10.4.17-1.el7.ius ius 233 k
mariadb104-libs x86_64 3:10.4.17-1.el7.ius ius 158 k
mariadb104-server x86_64 3:10.4.17-1.el7.ius ius 17 M
php74-gmp x86_64 7.4.30-1.el7.ius ius 78 k
Transaction Summary
Install 1 Package (+6 Dependent packages) Upgrade 2 Packages The updates were successfully applied
/etc/cron.daily/trim-txrep:
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2)
Unfortunately, since then emails are not sent to Office 365 to the destination server: princ-cz.mail.protection.outlook.com
Emails remain in the outgoing queue with an explanation:
(Host or domain name not found. Name service error for name=princ-cz.mail.protection.outlook.com type=A: Host not found, try again)
I've tried via shell nslookup to different servers, also ping and all of them work except for the server mentioned above.
It was working without problems until yesterday.
Where could be the problem that only this DNS entry can't be forwarded/translated??
In /etc/resolv.conf I have:
nameserver 127.0.0.1Code: Select all
dns_available yes
dns_server 127.0.0.1Code: Select all
forward-zone:
forward-addr: 193.17.47.1 # First DNS Server
forward-addr: 185.43.135.1 # Second DNS Server
forward-first: yesCode: Select all
nmcli con mod ens192 ipv4.dns "127.0.0.1"
nmcli con mod ens192 ipv4.ignore-auto-dns yes
nmcli con down ens192
nmcli con up ens192Thanks for any help.
