EFA v4- Pyzor error
Posted: 16 May 2022 04:14
I’m testing EFA-4 on Rocky Linux-8.5 but getting the following pyzor error –
echo "test" | spamassassin -D pyzor 2>&1 | less
May 16 09:52:17.472 [3877] dbg: pyzor: network tests on, attempting Pyzor
May 16 09:52:19.728 [3877] dbg: pyzor: pyzor is available: /usr/bin/pyzor
May 16 09:52:19.729 [3877] dbg: pyzor: opening pipe: /usr/bin/pyzor check < /tmp/.spamassassin3877NEWW0htmp
May 16 09:52:19.738 [3883] info: util: setuid: ruid=0 euid=0 rgid=0 0 egid=0 0
May 16 09:52:19.742 [3877] info: pyzor: [3883] error: exit 6
May 16 09:52:19.742 [3877] dbg: pyzor: got response: May 16 09:52:19.739 [3883] warn: Can't exec "/usr/bin/pyzor": No such file or directory at /usr/share/perl5/vendor_perl/Mail/SpamAssassin/Util.pm line 1794.\nMay 16 09:52:19.739 [3883] warn: util: failed to spawn a process "/usr/bin/pyzor, check": exec failed: at /usr/share/perl5/vendor_perl/Mail/SpamAssassin/Util.pm line 1795. at /usr/share/perl5/vendor_perl/Mail/SpamAssassin/Util.pm line 1699.
May 16 09:52:19.743 [3877] dbg: pyzor: failure to parse response "May 16 09:52:19.739 [3883] warn: Can't exec "/usr/bin/pyzor": No such file or directory at /usr/share/perl5/vendor_perl/Mail/SpamAssassin/Util.pm line 1794."
May 16 09:52:19.743 [3877] dbg: pyzor: failure to parse response "May 16 09:52:19.739 [3883] warn: util: failed to spawn a process "/usr/bin/pyzor, check": exec failed: at /usr/share/perl5/vendor_perl/Mail/SpamAssassin/Util.pm line 1795. at /usr/share/perl5/vendor_perl/Mail/SpamAssassin/Util.pm line 1699."
May 16 09:52:19.752 [3877] info: rules: meta test KAM_JURY has dependency 'KAM_RAPTOR_ALTERED' with a zero score
May 16 09:52:19.752 [3877] info: rules: meta test KAM_CARD has dependency 'KAM_RPTR_SUSPECT' with a zero score
May 16 09:52:19.753 [3877] info: rules: meta test KAM_INSURE has dependency 'CBJ_GiveMeABreak' with a zero score
May 16 09:52:19.755 [3877] info: rules: meta test KAM_PAYROLL_SCANNER has dependency 'KAM_IFRAME' with a zero score
May 16 09:52:19.755 [3877] info: rules: meta test KAM_WARRANTY has dependency 'CBJ_GiveMeABreak' with a zero score
May 16 09:52:19.757 [3877] info: rules: meta test KAM_AUTO has dependency 'CBJ_GiveMeABreak' with a zero score
May 16 09:52:19.759 [3877] info: rules: meta test KAM_FAKE_INVOICE has dependency 'KAM_RAPTOR_ALTERED' with a zero score
May 16 09:52:19.763 [3877] info: rules: meta test JMQ_CONGRAT has dependency 'KAM_RAPTOR_ALTERED' with a zero score
May 16 09:52:19.765 [3877] info: rules: meta test KAM_WARRANTY3 has dependency 'CBJ_GiveMeABreak' with a zero score
May 16 09:52:19.766 [3877] info: rules: meta test KAM_NOTIFY2 has dependency 'KAM_IFRAME' with a zero score
May 16 09:52:19.770 [3877] info: rules: meta test KAM_FAKE_DELIVER has dependency 'KAM_RAPTOR_ALTERED' with a zero score
May 16 09:52:19.772 [3877] info: rules: meta test KAM_INSURE2 has dependency 'CBJ_GiveMeABreak' with a zero score
May 16 09:52:19.774 [3877] info: rules: meta test KAM_BADPDF2 has dependency 'KAM_RPTR_SUSPECT' with a zero score
May 16 09:52:19.774 [3877] info: rules: meta test KAM_REALLY_FAKE_DELIVER has dependency 'KAM_RPTR_PASSED' with a zero score
pyzor ping
-bash: /usr/bin/pyzor: /usr/bin/python: bad interpreter: No such file or directory
