Email flow diagram - whitelisting before blacklisting (help)
rangerdth
Post by rangerdth »
I found a couple threads about an email flow diagram from 2015, but nothing more recent.
The mailscanner guide (someone linked here: https://s3.amazonaws.com/mailscanner/do ... -guide.pdf ) is a good reference, on page 8 (the numbered page 8).
What I think we have an issue with right now is that the blacklists are getting evaluated before the whitelist.
So, if we have support@company.com whitelisted to everyone, but emails are getting bounced due to a blacklist.
I would like to fix that (i.e. invert the whitelist check to be before the blacklist), or if this is a known issue, can anyone help?
rangerdth
Re: Email flow diagram - whitelisting before blacklisting (help)
Post by rangerdth »
In a reply to my original message, I didn't find a flow diagram, but I did find the relevant sections in the MailScanner docs:
https://www.mailscanner.info/MailScanne ... Not%20Spam
This definitively says that the whitelist is read before the blacklist.
I now believe my problem lies in postfix RBL's, as those are evaluated before MailScanner takes over.
What do your log files show for the rejected messages?
rangerdth
Post by rangerdth »
pdwalker wrote: 11 May 2022 14:37 What do your log files show for the rejected messages?
EDITED MY ORIGINAL REPLY for a better example:
May 11 02:21:41 mx02 postfix/smtpd[11027]: NOQUEUE: reject: RCPT from hwsrv-968541.hostwindsdns.com[104.168.204.250]: 554 5.7.1 Service unavailable; Client host [104.168.204.250] blocked using zen.spamhaus.org; Error: open resolver; https://www.spamhaus.org/returnc/pub/172.68.53.64; from=<somone@someplace.com> to=<support@company.com> proto=ESMTP helo=<hwsrv-968541.hostwindsdns.com>
yes, that is the postfix RBL check rejecting the message before it arrives in the system.
So, if you want to receive those messages, turn off the RBL checks in postfix.
I don't, because they seem to be pretty good at identifying spam before it enters my system.
rangerdth
Post by rangerdth »
pdwalker wrote: 12 May 2022 05:50 yes, that is the postfix RBL check rejecting the message before it arrives in the system.
Thanks for the reply.
One thing that had me concerned was the reference to "open resolver". That really sounded like my system had an issue.
I think that means that the sending site had an open resolver.
