Firstly, I know, I should not be bouncing spam, which I don't want to do but my managers insist that I have it configured that all low score spam be bounced, not just from specific domains.
I have tested this by adding a rule to bounce.rules to bounce spam from gmail.com, waiting for MailScanner to restart and sending a mail that will get caught as spam from my GMail account.
This works perfect.
My logic was that if I then remove this rule, and edit the default rule to have Action "yes", wait for MailScanner to restart and test again, that low scoring spam will bounce, but this is not happening at all.
Should I add my own "catchall" rule to bounce low score spam, and if so, what will the correct syntax be?
Will something like "From: * yes" work?
Thank you in advance
