Modify Quarantine Report Email
Posted: 23 Mar 2022 21:48
by traverss
I was wondering if there is a way to modify the quarantine email report to remove columns as well as the width of these?
The reason being is that the email doesn't seem to render that well on iphones etc
I was wanting to remove the "To" column as well as shrink the "subject" column.
Thanks in advance
Re: Modify Quarantine Report Email
Posted: 24 Mar 2022 09:18
by freyuh
You have to edit /var/www/html/mailscanner/quarantine_report.inc.php
Ulrich.
Posted: 25 Mar 2022 18:35
If you do edit the file (it's pretty easy), make sure you back up the original in case you make a little mistake.
Also, after you have made the changes you like, make a backup copy of that as an update will overwrite your changes. Don't ask me how many times I've made customizations that got wiped out because I couldn't be bothered to make a copy. Doh!
cp quarantine_report.inc.php quarantine_report.inc.php.org
// make your edits and when you're happy
cp quarantine_report.inc.php quarantine_report.inc.php.new
