Where to find EFA version.
ramtech
Post by ramtech »
I know this will be a dumb question, but where do i find the EFA version I am on? I can't see it in the GUI and I couldn't find it in any of the settings or conf files. The GUI Software Versions Links doesn't seem to show it either.
Re: Where to find EFA version.
/etc/EFA-Version
:shhh:
ramtech
Post by ramtech »
:snooty:
I won't tell a soul!
:whistle:
Ta Shawn.
ovizii
Post by ovizii »
apparently v. 3.0.1.2 as added the EFA version to the GUi and yet I still cannot find it.
I just realized that I cannot find the efa version number in the mailscanner web ui either.
dbrunt
Post by dbrunt »
It displays below the login box:
http://efa.your_domain.com/mailscanner/login.php
good heavens! who actually looks at the login page?
i expected to see the version number after i logged in.
next you'll be telling me to read the manuals!
ovizii
Post by ovizii »
pdwalker wrote:good heavens! who actually looks at the login page?
exactly! I'm permanently logged in and shouldn't the version rather be hidden for non-logged in users in case some security issues arise? aka security by obscurity?
dbrunt
Post by dbrunt »
I agree! It's slightly better than having to run /etc/EFA-Version at the shell prompt though!
Yeah, I concur. If something is later discovered with a particular version, it is too easy to fingerprint.
I am going to move it into MailWatch interface instead.
https://github.com/E-F-A/v3/issues/331
:clap:
shawniverson,
I've added a comment with some of the changes I made to the status.php page. You may or may not find them useful for you.
