Mailwatch don't work
vbarbieri
Post by vbarbieri »
Please help me , I can not access the web page, perhaps mistake the 'url? use http://antispamhostname
Re: Mailwatch don't work
Did you try accessing by IP address instead to make sure you aren't having a DNS issue?
vbarbieri
Post by vbarbieri »
yes i try to connect via ip and hostname but don't work
Can you ping either?
If not, the problem is most likely the host and/or VM Network configuration.
