Disable CLAM/D?
jheffez
Disable CLAM/D?
Post by jheffez »
What's the best way to disable clam (everything clam-related: clam/clamd/unofficial signature related)?
What other steps can I take to reduce memory consumption?
I need every bit of memory I can spare. I've tried various settings to limit clam hog behavior to no avail. It's still taking too many resources I can't spare.
Using eFa-4.0.4.
Thank you.
Re: Disable CLAM/D?
You can set the following...
Virus Scanners = none
and then disable clamd/clamd updates and clamav-unofficial-sigs updates
