hi,
now that eFa4 has been updated to detect and install on Rocky 8, what about existing installations?
Is it possible to convert an exsiting eFa4 installation with CentOS 8 to Rocky Linux 8? Or is better to do a fresh installation?
The conversion of the OS itself is no problem, well documented, tried and tested.
regards,
Reinhard
Convert from CentOS 8 to Rocky
Re: Convert from CentOS 8 to Rocky
I haven't tested it with eFa but will give it a try.
I upgraded my system today from Centos to Rocky. From what I can tell there are no issues. I verified mail flow and the webui seems fully functional. Always possible I am missing something, but initially, it looks good.
well, I wasn't lucky with the migration script and did a fresh install followed by a "System Restore" - this seemed the fastest way to get the mailserver up&running again
problem was the "dnf distro-sync" of the migration script and different versions in eFa- and EPEL-Repo, here is the error message:
Syncing packages
Last metadata expiration check: 0:00:05 ago on Tue Feb 8 11:33:06 2022.
Error:
Problem 1: package perl-MooX-StrictConstructor-0.010-1.eFa.el8.noarch requires perl(Moo::Role) >= 2.003006, but none of the providers can be installed
- package perl-MooX-StrictConstructor-0.010-1.eFa.el8.noarch requires perl-Moo >= 2.003006, but none of the providers can be installed
- cannot install both perl-Moo-2.003004-7.el8.noarch and perl-Moo-2.003006-1.eFa.el8.noarch
- cannot install both perl-Moo-2.003006-1.eFa.el8.noarch and perl-Moo-2.003004-7.el8.noarch
- cannot install the best update candidate for package perl-MooX-StrictConstructor-0.010-1.eFa.el8.noarch
- cannot install the best update candidate for package perl-Moo-2.003006-1.eFa.el8.noarch
Problem 2: package perl-GeoIP2-Country-Reader-2.006002-1.eFa.el8.noarch requires perl-List-SomeUtils >= 0.58, but none of the providers can be installed
- cannot install both perl-List-SomeUtils-0.56-8.el8.noarch and perl-List-SomeUtils-0.58-1.eFa.el8.noarch
- cannot install both perl-List-SomeUtils-0.58-1.eFa.el8.noarch and perl-List-SomeUtils-0.56-8.el8.noarch
- cannot install the best update candidate for package perl-List-SomeUtils-0.58-1.eFa.el8.noarch
- cannot install the best update candidate for package perl-GeoIP2-Country-Reader-2.006002-1.eFa.el8.noarch
Problem 3: package perl-Math-Int128-0.22-1.eFa.el8.x86_64 requires perl-Sub-Quote >= 2.006006, but none of the providers can be installed
- cannot install both perl-Sub-Quote-2.006003-3.el8.noarch and perl-Sub-Quote-2.006006-1.eFa.el8.noarch
- cannot install both perl-Sub-Quote-2.006006-1.eFa.el8.noarch and perl-Sub-Quote-2.006003-3.el8.noarch
- cannot install the best update candidate for package perl-Sub-Quote-2.006006-1.eFa.el8.noarch
- cannot install the best update candidate for package perl-Math-Int128-0.22-1.eFa.el8.x86_64
Problem 4: package eFa-1:4.0.4-26.eFa.el8.noarch requires sqlgrey >= 1:1.8.0-8, but none of the providers can be installed
- cannot install both sqlgrey-1.8.0-22.el8.noarch and sqlgrey-1:1.8.0-8.el8.noarch
- cannot install both sqlgrey-1:1.8.0-8.el8.noarch and sqlgrey-1.8.0-22.el8.noarch
- cannot install the best update candidate for package sqlgrey-1:1.8.0-8.el8.noarch
- cannot install the best update candidate for package eFa-1:4.0.4-26.eFa.el8.noarch
(try to add '--allowerasing' to command line to replace conflicting packages or '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
Error during distro-sync
Syncing packages
Error:
before running the script i edited the repos from their current to vault.centos.org and disabled-re-enabled them. I was able to proceed with the upgrade script at that point and didn't encounter any issues. I was prompted to do so because I otherwise didn't have git on the system to grab the script.
successfully migrated my other mailserver to Rocky Linux without any problems
The problem with my first server was that several RPMs do have the identical names in eFa- and EPEL-repos, and so the migration script failed. I worked around this problem by excluding several packages from the EPEL-repos.
/etc/yum.repos.d/epel.repo:
[epel]
name=Extra Packages for Enterprise Linux $releasever - $basearch
#baseurl=https://download.fedoraproject.org/pub/ ... /$basearch
metalink=https://mirrors.fedoraproject.org/metal ... contentdir
enabled=1
gpgcheck=1
countme=1
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-EPEL-8
# exclude RPMs from eFa
exclude=python3-unbound perl-List-SomeUtils perl-GeoIP2-Country-Reader eFa-4 eFa-base perl-Sub-Quote perl-Sys-Hostname-Long perl-List-UtilsBy perl-IP-Country-DB_File unrar perl-Net-Works-Network perl-MaxMind-DB-Metadata perl-Net-DNS-Resolver-Programmable unbound perl-Encoding-FixLatin postfix_eFa perl-Scalar-List-Utils perl-Role-Tiny spamassassin_eFa MailWatch perl-Data-IEEE754 perl-MaxMind-DB-Reader perl-Net-DNS MailScanner perl-List-AllUtils perl-Moo perl-IP-Country-2 perl-Math-BigInt-FastCalc perl-Math-Int128 sqlgreywebinterface unbound-libs perl-MaxMind-DB-Reader perl-Mail-SPF-Query perl-Sendmail-PMilter perl-Math-Int64 dcc perl-Data-Printer perl-MooX-StrictConstructor sqlgrey
/etc/yum.repos.d/epel-modular.repo:
[epel-modular]
name=Extra Packages for Enterprise Linux Modular $releasever - $basearch
enabled=1
gpgcheck=1
countme=1
[epel]
enabled=1
gpgcheck=1
countme=1
[epel-modular]
enabled=1
gpgcheck=1
countme=1
I ran into the same problem and while the exclusions did the trip to get past this issue, I was concerned about having a static exclusion list from a maintenance perspective. As an alternative, I raised the priority of the eFa repo by adding the line 'priority=49' to the end of /etc/yum.repos.d/eFa4.repo.Reinhard wrote: 16 Feb 2022 11:12 The problem with my first server was that several RPMs do have the identical names in eFa- and EPEL-repos, and so the migration script failed. I worked around this problem by excluding several packages from the EPEL-repos.
From https://dnf.readthedocs.io/en/latest/conf_ref.html :
I removed the packages, removed the excludes and then re-ran the install with this priority mod in place and it seems to have gone well (so far at least).priority
integer
The priority value of this repository, default is 99. If there is more than one candidate package for a particular operation, the one from a repo with the lowest priority value is picked, possibly despite being less convenient otherwise (e.g. by being a lower version).
I have my "empty" system built without having done the initial configuration. I then tried System Restore but I ended up with an unbootable system the two times I tried it. Can somebody help me with what the secret sauce in this process is?Reinhard wrote: 08 Feb 2022 17:14 well, I wasn't lucky with the migration script and did a fresh install followed by a "System Restore" - this seemed the fastest way to get the mailserver up&running again
To setup for the restore, I used sftp to drag over the gz files from /var/eFa/backup on the live system to the new system. These backups are the regularly scheduled daily backups.
After an initial fail on the restore involving the database, I also copied over /etc/eFa/MySQL-Config .
with all this in place, I did sudo /usr/sbin/eFa-Configure and chose the option for System Restore. The restore starts off well enough, but then comes across some problems:
Proceed with restore? (y/N)
y
Beginning Restore of /var/eFa/backup/backup-20220308-034908.tar.gz...
./backup/
./backup/sql/
./backup/sql/backup.sql
./backup/etc/
./backup/etc/postfix/
./backup/etc/postfix/ssl/
./backup/etc/postfix/ssl/dhparam.pem
./backup/etc/postfix/ssl/smtpd.pem
./backup/etc/postfix/dynamicmaps.cf
./backup/etc/postfix/main.cf
(skipped lines)
./backup/var/www/
./backup/var/www/html/
./backup/var/www/html/mailscanner/
./backup/var/www/html/mailscanner/conf.php
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2)
Error: Database connection failed: it is possible that the database is overloaded or otherwise not running properly; contact the system administrator if the problem persists
shell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
Version check failed. Got the following error when calling the 'mysql' command line client
FATAL ERROR: Upgrade failed
Restore Complete!
A restart is needed to complete restore. Press enter to reboot.
I am more concerned with the fail on the restore than the unbootable system. I am assuming that fixing the first problem will deal with the second. I am able to restage the system to just before the restore operation by executing a Veeam bare metal restore, so restaging for another attempt is not too big of a deal.
Any ideas?
Try running through the initial setup first then run the restore.
