SPF and Client IP in SpamHaus
conceptid
Post by conceptid »
A user is registered to logon in EFA to send email (remote SMTP). EFA is efa.domainA.ca. The user send email with user@domaineB.ca.
If I go to see spam rules apply to each email, I have some problems with high spam score... One of the rules is "spf fail". But... the domainB DNS has a TXT record with SPF and "a:efa.domaineB.ca".
What I missed?
Another problem is that spam scores increase by 3.33 for an authenticated user IP in SpamHaus PBL... But I don't understand, it's is public home router IP (he is behind a NAT) and he is sending from Outlook (or Thunderbird not difference) to EFA directly. Sender IP shouldn't have impact... it's not an smtp relay...
Last thing, if the user use Outlook, a rule for outlook header appear...
This is the list of all rules applied...
-1.90	BAYES_00						Bayes spam probability is 0 to 1%
1.10		DCC_CHECK					Detected as bulk mail by DCC (dcc-servers.net)
2.84		DOS_OUTLOOK_TO_MX			Delivered direct to MX with Outlook headers
0.00		DYN_RDNS_SHORT_HELO_HTML		Sent by dynamic rDNS, short HELO, and HTML
1.57		FSL_BULK_SIG					Bulk signature with no Unsubscribe
0.00		FSL_HELO_NON_FQDN_1
0.00		HELO_NO_DOMAIN				Relay reports its domain incorrectly
1.40		HTML_IMAGE_ONLY_28			HTML: images with 2400-2800 bytes of words
0.00		HTML_MESSAGE				HTML included in message
0.40		KHOP_HELO_FCRDNS				Relay HELO differs from its IP's reverse DNS
0.00		PDS_RDNS_DYNAMIC_FP			RDNS_DYNAMIC with FP steps
3.33		RCVD_IN_PBL					Received via a relay in Spamhaus PBL
0.00		RCVD_IN_SORBS_DUL			SORBS: sent directly from dynamic IP address
0.98		RDNS_DYNAMIC					Delivered to internal network by host with dynamic-looking rDNS
0.67		SPF_SOFTFAIL					SPF: sender does not match SPF record (softfail)
-1.86	TXREP						Score normalizing based on sender's reputation
0.01		T_REMOTE_IMAGE				Message contains an external image
Also, I would like that all authenticated users using EFA for SMTP to pass free all spam rules... Without whitelisting email adresses (if I do that, spoofing will be possible) Possible to do that? How?
Something to fix here? (I am not sure to understand perfectly what this do...)
smtpd_helo_restrictions = check_helo_access hash:/etc/postfix/helo_access, reject_invalid_hostname
smtpd_client_restrictions = permit_sasl_authenticated, permit_mynetworks, reject_rbl_client zen.spamhaus.org
smtpd_relay_restrictions = permit_sasl_authenticated, permit_mynetworks, reject_unauth_destination
smtpd_recipient_restrictions = permit_sasl_authenticated, permit_mynetworks, reject_unauth_destination, reject_non_fqdn_recipient, reject_unknown_recipient_domain, check_recipient_access hash:/etc/postfix/recipient_access, check_policy_service inet:127.0.0.1:2501, reject_unverified_recipient
These files are empty:
[conceptid@efa postfix]$ ls -al *access
-rw-r--r--. 1 root root 21519 Apr 9 2020 access
-rw-r--r--. 1 root root 0 Apr 9 2020 helo_access
-rw-r--r--. 1 root root 0 Apr 9 2020 recipient_access
-rw-r--r--. 1 root root 0 Apr 9 2020 sender_access
Re: SPF and Client IP in SpamHaus
Take a look at /etc/MailScanner/MailScanner.conf:
# Postfix/Exim only: (yes/no)
# If an user sends a mails after authenticating to the local mta
# this option disables the rbl checks if set to "yes". If set to "no" or not
# defined the rbl check will be executed even when the user is authenticated.
Spam List Skip If Authenticated = yes
conceptid
Post by conceptid »
Thanks a lot! You are very nice.
I think it works now, I remove RBL check for auth users.
Now, what about this one for auth users?
and this one when a user use Outlook to send (auth) with EFA:
conceptid
Post by conceptid »
Didn't work for a certain user using Outlook to send with Avast on the desktop... Spamhaus is checked... IP is blacklist... and spam score is too high.
conceptid
Post by conceptid »
shawniverson wrote: 12 Jan 2022 14:49 Take a look at /etc/MailScanner/MailScanner.conf:
Didn't work, seems to have no effect.
Yes I restarted MailScanner and also I rebooted the vm...
What is your version of MailScanner currently?
rpm -qa | grep MailScanner
