I install efa on Roky Linux 8.5, all good, but i have this situation: when i want to see MailScanner configuration from Tools and links after click sesion is Time Out.
And also i didn't see relay information.
Can you help with this problem?
Thanq
Session time out
Re: Session time out
Can you provide any additional details about how you are set up?
I can spin up a Rocky instance and see if I can locate the issues.
Now problem disapear, i think it was an broswer or coockie problem with time out session, and after abou 30 min or more replay information appear.
Maybe it's an cron or another procces that works after couple of minute.
Also i have instaled CSF firewall, and i maybe an problem regarded restrict_syslog setting.
Thanq
Thanq
