Update to MailScanner-5.4.2-3 - htmlpurifier
Posted: 01 Dec 2021 13:24
After an update this morning to MailScanner-5.4.2-3
I noticed 2 errors in
1.
[01-Dec-2021 12:10:21 Europe/Amsterdam] PHP Notice: Undefined variable: dir in /var/www/html/mailscanner/msmail.inc.php on line 33
After a reboot this one is gone. ( due the restart of Mailscanner?)
2.
[01-Dec-2021 12:17:07 Europe/Amsterdam] PHP Warning: Directory /var/www/html/mailscanner/lib/htmlpurifier/standalone/HTMLPurifier/DefinitionCache/Serializer not writable, please chmod to 777 in /var/www/html/mailscanner/lib/htmlpurifier/HTMLPurifier.standalone.php on line 15816
For the second one I had a look at http://htmlpurifier.org/download
To get rid of the error I executed:
Shawn can you comment on this solution?
/var/log/php-fpm/www-error.log[01-Dec-2021 12:10:21 Europe/Amsterdam] PHP Notice: Undefined variable: dir in /var/www/html/mailscanner/msmail.inc.php on line 33
2.
Installation
File permissions
HTML Purifier will write out cache files for HTMLDefinition in the subdirectories of HTMLPurifier/DefinitionCache/Serializer. If you are in the library/ folder of HTML Purifier, you can set the appropriate permissions using:
chmod -R 0755 HTMLPurifier/DefinitionCache/Serializer
If the above command doesn't work, you may need to assign write permissions to all. This may be necessary if your webserver runs as nobody, but is not recommended since it means any other user can write files in the directory. Use:
chmod -R 0777 HTMLPurifier/DefinitionCache/SerializerCode: Select all
chmod -R 0777 /var/www/html/mailscanner/lib/htmlpurifier/standalone/HTMLPurifier/DefinitionCache/SerializerCode: Select all
ls -la /var/www/html/mailscanner/lib/htmlpurifier/standalone/HTMLPurifier/DefinitionCache/SerializerCode: Select all
total 0
drwxrwxrwx. 3 root root 36 Dec 1 14:02 .
drwxr-xr-x. 3 root root 24 Nov 22 03:14 ..
drwxr-xr-x 2 php-fpm php-fpm 67 Dec 1 14:02 HTML
-rwxrwxrwx 1 root root 0 Nov 22 03:14 index.htmlShawn can you comment on this solution?
