again some troubles, because of linux knowledge gaps.
As you might know, i use EFA differently than thought by shawn - not as directly reachable SMTP Gateway for Exchange (Tobit David) Servers.
The EFA is behind a firewall, and i get my mails via fetchmail pop3, and the EFA relays the "fetchmail-received" mails to 3 different Exchange (Tobit) Servers as defined the the postfix transport settings.
The domain settings are hosted by an isp service provider - also the mx records for the domains.
If i try to release a quaratine message, the efa tries to send them via relay of the isp mailservers instead to relay them diretly to the internal Exchange /Tobit) Servers - how can i fix this relaying the quaratined messages directly to the Exchange Servers ?
Nov 24 09:21:14 mw24mailgate postfix/pickup[123139]: 4HzYqt38Ndz8DDr: uid=997 from=<MW24MAILGATE@elektro-musswessels.de>
Nov 24 09:21:14 mw24mailgate opendmarc[3121]: ignoring connection from localhost
Nov 24 09:21:14 mw24mailgate postfix/cleanup[123644]: 4HzYqt38Ndz8DDr: message-id=<30177982.20211123140524.619cf52412efd1.81721641@mail.moreapp.com>
Nov 24 09:21:17 mw24mailgate opendkim[3125]: 4HzYqt38Ndz8DDr: message has signatures from moreapp.com, mandrillapp.com
Nov 24 09:21:17 mw24mailgate opendkim[3125]: 4HzYqt38Ndz8DDr: DKIM verification successful
Nov 24 09:21:17 mw24mailgate postfix/qmgr[39653]: 4HzYqt38Ndz8DDr: from=<MW24MAILGATE@elektro-musswessels.de>, size=887635, nrcpt=1 (queue active)
Nov 24 09:21:18 mw24mailgate postfix/smtp[123650]: 4HzYqt38Ndz8DDr: to=<verwaltung@elektro-musswessels.de>, relay=mx00.kundenserver.de[212.227.15.41]:25, delay=4, delays=2.8/0.02/0.77/0.39, dsn=2.0.0, status=sent (250 Requested mail action okay, completed: id=1MbS4f-1mDzjb0BxJ-00bpQP)
Nov 24 09:21:18 mw24mailgate postfix/qmgr[39653]: 4HzYqt38Ndz8DDr: removed
best regards,
Frank
