Running out of disk space
Trikke
Post by Trikke »
eFa 4.0.4 - CentOS 7
Free Disk Space
/ 5.52GB [11%]
/boot 772.73MB [76%]
/home 100.95GB [100%]
/tmp 5.52GB [11%]
/var/tmp 5.52GB [11%]
/ = 50GB
/home = 100GB
Everyting eFa gets stored in/var/spool/MailScanner/quarantine (=36GB)
So effectively, only 1/3, of available disk space is used?
Is it possible to move quarantine to /home?
Re: Running out of disk space
Partitioning is done on eFa4 based on whatever you chose when you installed the OS.
You should not try to move it to /home, instead, you may want to add a new disk or expand the existing disk. If you add a new disk, you can mount it to /var/spool/MailScanner/quarantine (after moving stuff there with a temporary mount in /mnt) or expand the partition and filesystem for root.
If you are constrained for space, you can create a new, smaller /home partition and move /home to the new partition and dump the old /home. If you used LVM then it should be fairly straightforward to allocate the freed up space to root.
