I just tried setting up a test instance of eFa 4 on CentOS Stream 8 and ran into the following errors:
2021.10.29-15:22:45 - =============  EFA4 BUILD SCRIPT STARTING  ============
2021.10.29-15:22:45 - Good you are root.
2021.10.29-15:22:45 - Good you are running CentOS 8
2021.10.29-15:22:45 - Checking network connectivity
2021.10.29-15:22:45 - OK - https://mirrors.efa-project.org is reachable
2021.10.29-15:22:45 - Enabling CentOS 8 PowerTools Repo
2021.10.29-15:22:45 - Updating the OS
Invalid configuration value: failovermethod=priority in /etc/yum.repos.d/eFa4.repo; Configuration: OptionBinding with id "failovermethod" does not exist
CentOS Stream 8 - PowerTools                     17 kB/s | 4.4 kB     00:00
Error:
 Problem 1: cannot install the best update candidate for package perl-libnet-3.11-3.el8.noarch
  - nothing provides perl(:MODULE_COMPAT_5.16.3) needed by perl-libnet-1:3.11-1.eFa.el7.x86_64
 Problem 2: cannot install the best update candidate for package python3-unbound-1.7.3-17.el8.x86_64
  - nothing provides libevent-2.0.so.5()(64bit) needed by python3-unbound-1.11.0-1.eFa.el7.x86_64
 Problem 3: cannot install the best update candidate for package unbound-libs-1.7.3-17.el8.x86_64
  - nothing provides libevent-2.0.so.5()(64bit) needed by unbound-libs-1.11.0-1.eFa.el7.x86_64
(try to add '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
2021.10.29-15:22:47 - Removing conflicting packages
2021.10.29-15:22:47 - Installing eFa packages (This can take a while)
Last metadata expiration check: 0:00:02 ago on Fri 29 Oct 2021 03:22:46 PM CEST.
Error:
 Problem: cannot install the best candidate for the job
  - nothing provides perl-Math-Int64 >= 0.52 needed by eFa-1:4.0.4-18.eFa.el7.noarch
  - nothing provides perl-Net-DNS-Nameserver >= 0.72-6 needed by eFa-1:4.0.4-18.eFa.el7.noarch
  - nothing provides perl-Net-DNS-Resolver-Programmable >= 0.003-15 needed by eFa-1:4.0.4-18.eFa.el7.noarch
  - nothing provides perl-Sys-Hostname-Long >= 1.5-1 needed by eFa-1:4.0.4-18.eFa.el7.noarch
  - nothing provides policycoreutils-python >= 2.5-17.1 needed by eFa-1:4.0.4-18.eFa.el7.noarch
  - nothing provides python2-certbot-apache >= 0.29.1-1 needed by eFa-1:4.0.4-18.eFa.el7.noarch
  - nothing provides sqlgrey >= 1.8.0-8 needed by eFa-1:4.0.4-18.eFa.el7.noarch
  - nothing provides system-config-keyboard >= 1.4.0-4 needed by eFa-1:4.0.4-18.eFa.el7.noarch
  - nothing provides tnef >= 1.4.15-1 needed by eFa-1:4.0.4-18.eFa.el7.noarch
  - nothing provides yum-cron >= 3.4.3-154 needed by eFa-1:4.0.4-18.eFa.el7.noarch
  - nothing provides php74-common >= 7.4.15-1 needed by eFa-1:4.0.4-18.eFa.el7.noarch
  - nothing provides mod_php74 >= 7.4.15-1 needed by eFa-1:4.0.4-18.eFa.el7.noarch
  - nothing provides php74-cli >= 7.4.15-1 needed by eFa-1:4.0.4-18.eFa.el7.noarch
  - nothing provides php74-fpm >= 7.4.15-1 needed by eFa-1:4.0.4-18.eFa.el7.noarch
  - nothing provides php74-gd >= 7.4.15-1 needed by eFa-1:4.0.4-18.eFa.el7.noarch
  - nothing provides php74-json >= 7.2.5-2 needed by eFa-1:4.0.4-18.eFa.el7.noarch
  - nothing provides php74-ldap >= 7.4.15-1 needed by eFa-1:4.0.4-18.eFa.el7.noarch
  - nothing provides php74-mbstring >= 7.4.15-1 needed by eFa-1:4.0.4-18.eFa.el7.noarch
  - nothing provides php74-mysqlnd >= 7.4.15-1 needed by eFa-1:4.0.4-18.eFa.el7.noarch
  - nothing provides php74-pdo >= 7.4.15-1 needed by eFa-1:4.0.4-18.eFa.el7.noarch
  - nothing provides php74-process >= 7.2.5-2 needed by eFa-1:4.0.4-18.eFa.el7.noarch
  - nothing provides php74-xml >= 7.4.15-1 needed by eFa-1:4.0.4-18.eFa.el7.noarch
  - nothing provides mariadb102-server >= 3:10.2.30-1 needed by eFa-1:4.0.4-18.eFa.el7.noarch
  - nothing provides mariadb102 >= 3:10.2.30-1 needed by eFa-1:4.0.4-18.eFa.el7.noarch
  - nothing provides mariadb102-common >= 3:10.2.30-1 needed by eFa-1:4.0.4-18.eFa.el7.noarch
  - nothing provides mariadb102-libs >= 3:10.2.30-1 needed by eFa-1:4.0.4-18.eFa.el7.noarch
2021.10.29-15:22:49 - ERROR: eFa4 failed to install
2021.10.29-15:22:49 - ^^^^^^^^^^ SCRIPT ABORTED ^^^^^^^^^^The same behavior also appears when trying to use install eFa on Rocky 8.4.
Am I missing something?
Tom
P.S.: I don't think this is related, but https://mirrors.efa-project.org/rpm/eFa4/eFa4.repo throws 500s sometimes instead of returning the repo.
[root@mx ~]# curl -L https://mirrors.efa-project.org/rpm/eFa4/eFa4.repo
<html>
<head><title>500 Internal Server Error</title></head>
<body>
<center><h1>500 Internal Server Error</h1></center>
<hr><center>nginx/1.20.1</center>
</body>
</html>
