Hello!
Sometimes the EFA is blocking .xlsx files.
The message is: "MailScanner: No programs allowed"
How can I fix it?
Best regards: Péter
Re: MailScanner: No programs allowed
check /etc/MailScanner/filename.rules.conf
BTW are you sure that those files are not *.xlsx.exe?
Hi!
I'm sure 100%, that theese files normal xlsx or xls.
What do I check in /etc/MailScanner/filename.rules.conf ?
Best regards: Péter
Best regards: Péter
Did you resolve this. I seem to have a similar issue with a .txt file
Hi Peter,
the file contains definition for behavior based on the file extension.
This way you can define which file types are allowed to pass and which are not.
Would someone take a look at this PR https://github.com/MailScanner/v5/pull/556 and set the following in MailScanner.conf:
Archive: Ignore DAT File Executable = yes
Hello!
Sorry the latest answer.
So, when the EFA blocking xlsx file, the complete message is: The message is: "MailScanner: No programs allowed (92000.dat)" or (90000.dat etc).
And really the xlsx content a few bytes size dat file.
I can rename xlsx to zip and I can see the xlsx contain a .dat file which was blocked.
Regards: Péter
Regards: Péter
