Efa over VPN
filips
Efa over VPN
Post by filips »
Hello, I have postfix on RPI4 and it's working standalone. On diffrent location I have Efa on x86. I have VPN between two locations (Draytek-Mikrotik).
IMAP is working very well, Efa is listning, but when I try to send some emails I have Relay access denied 554 5.7.1.
Two servers can ping each other and telnet services. Outbound mail relay on mail server is correct (mail server)
I don't know where the problem is. Postfix / efa / vpn
Added relay host and mynetworks efi IP
Re: Efa over VPN
I'm going to lean to a restriction in postfix.
Hatand
Re: Efa over VPN
Post by Hatand »
You can Close Submission Port and IMAP Port and reset it
