Quarantining Whitelist Mail
sem
Post by sem »
All mail passing through the filter on test (originating from using MUTT via the console to send externally) is being delivered ok but showing in the quarantine.
Status being shown is WL.
Is this anything to do with WL rules not being correctly applied here: http://baruwa-users-list.963389.n3.nabb ... 19502.html
darky83
Site Admin
Re: Quarantining Whitelist Mail
Post by darky83 »
localhost is whitelisted by default.
So if you send from the EFA console it will always be whitelisted.
sem
Post by sem »
Got you. Thanks.
