Constant error in fail2ban.log
yuljk
Post by yuljk »
Hi guys - Running on CentOS 8 with a fresh installation of eFa - after enabling fail2ban through efa-Configure I see the following error repeated multiple times in /var/log/fail2ban.log
fail2ban.filterpoll [828147]: ERROR Caught unhandled exception in main cycle: IntegrityError('FOREIGN KEY constraint failed',
I've tried deleting the fail2ban db and restarting the service - same issue.
Any ideas?
Re: Constant error in fail2ban.log
I would enable sql logging and then find out what sql insert statement is failing.
that would then help me figure out why the foreign key constraint is failing.
